RV.Net Open Roads Forum: Travel Trailers: Dumping black water??
 > Dumping black water??
emsdad
Va
Posted: 06/08/08 08:37am Link  |  Quote  |  Print  |  Notify Moderator
I am new to this and I have never had expiernce with this. I think its a pretty simple thing. I just purchased my Antiqua and it has some black water left in it. What do I do?? Can I call a local camp ground and take it there to dump? Do they have water supply there so I can wash out my tank? I purchased one of those things that you hook to a water hose and stick it in the tiolet to rinse tank.
handye9
Park City, IL 60085
Posted: 06/08/08 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Check with local RV dealers for information on dumping locations. Some may even have one.
Could also check with local truck stops. Many of them, also have RV dumps.
Edit your post with a more specific location and one of our members may be able to help you out.
Not all dump sites will have water available.
08 F250 Crewcab 4X4 Short bed
06 Flagstaff 831QBSS
Wife and I
Buddy the Beagle
USN MCPO (E9) Retired (active duty 1973 - 1995)
Check out my mods
pacificnw
Great Northwest
Posted: 06/08/08 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Go to a RV dump station, fill up your black tank with water, hook up your sewer line to the dump and pull the valve open. Rinse and repeat.
sctusa
Carrabelle, Fl.
Posted: 06/08/08 09:03am Link  |  Quote  |  Print  |  Notify Moderator
You might want to try this site to help you find a dump station. And welcome to the RV world!!!
Scott
2005 Dodge 3500 4X2 HO CTD Dually 6 Speed
2005 Springdale 266RELL GL
Reese HP Dual Cam
Prodigy BC
2 Honda EU2000i's
2 Lifeline 31 Series AGM 12V RV Batts
2006 Harley XL1200R
SP 2610 GPS
26" Samsung LCD HD TV
John3872
Iowa
A lot of rest areas have a place where you can dump your tanks. If you are close to one these are usually pretty convenient.
2001 GMC 2500 6.0L
2006 Rockwood 8281SS
Reese 16K Fifth Wheel Slider
DrawTite Brake Controller
ReneeG
Meridian, Idaho
Posted: 06/08/08 09:47am Link  |  Quote  |  Print  |  Notify Moderator
First of all, how much black water is still left in it - your monitoring system should give you an idea. If it's quite a bit - monitoring 1/3 or even a bright lit quarter full light, then I'd find a dump station nearby. Most, if not all, places have a water hose but often the ends are smashed or crooked so you can't always attach your hose to it. We currently have a black tank sprayer built in and visit a dump site with a good hose connection so we don't have a problem but before the black tank built in sprayer and good hose connection, this is what we would do (granted we have an RV pad beside our house to be able to do this in fewer steps) - We'd empty the tank at the dump station. Go home and hookup to our garden hose with the tank sprayer that you stick down the toilet. Then I would empty the black tank by bucket dumping in our laundry room bathroom. I would repeat these steps till the black tank water ran clear. Then I sanitize the bucket. A lot of steps, Yes, but this ensured that the tank was empty. I wouldn't always do this, especially if we were planning another trip soon but did this before winterizing. I would suggest also that you purchase a short connector tube that is clear. You attach this to your tank outlet before connecting your black and gray water sewer hose. This allows you to check when the water is running clear to ensure the tank is empty when you dump at the dump station while spraying down your toilet with your wand.
2006 282TS 32' Komfort
1999 Ford F250 4x4 XLT SD Triton V10 with Tow Package
Prodigy Brake Control
Magnaflow Cat Back Exhaust, FIPK, and TransGo Shift Kit
Hensley Arrow
Dave and Renee plus Champ, Molly (in spirit), Missy and now Maggie Along for the Ride!
A&K
Plainfield, IL
Posted: 06/08/08 10:11am Link  |  Quote  |  Print  |  Notify Moderator
You could always bite the bullet, buy a Flojet Macerating Pump and run your hose to a convenient sewer clean-out or home toilet.
Andy
Andy & Kathi
DD ('91), DD ('94), Woof ('92), Woof Woof ('03)
2003 Ford Explorer
2008 Jayco Jay Feather Sport 218
Our Picture's
JFG
TN
Posted: 06/08/08 10:14am Link  |  Quote  |  Print  |  Notify Moderator
What you have in your tank may be rv anti-freeze. the previous owner or dealer may have winterized it and it is still that way. Check with the previous owner or your dealer.
Fred
emsdad
Va
Posted: 06/08/08 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
My metersays it is 3/4 full. I am not sure if it is from winterizing or not? How much liquid do they normally put in for winteriztion? Either way I found a local campground that charges 10 bucks to dump.
coopdawg01
Corinth, Texas
Posted: 06/08/08 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
Why not just dump it the next time you go camping? Unless it's going to be a while. Any campground with ele and water hookups will have a dump station and water to flush with. Just my 2 cents.
Is it time to go home already?
2008 Gulfstream Kingsport 236 RB
2002 Ford F-150 5.4L Supercrew
