wfr1
Vacaville
We have spent the last hour searching RV net for information on skylights. Our question involves insulating ours against the intense summer sun here in the south west. the skylights let in large amounts of heat and light and the coach AC really struggles to keep it cool. We are thinking of getting foam insulation to fill them to keep out the heat during mid-day periods but are concerned about the heat build up in them damaging the skylights. The vented ones we can open slightly but the sealed ones (non opening) are a real concern. Can anyone offer any insights? I know CW sells the foam inserts.
Thanks
Bill and Carole
2K8 Chevy LTZ Turbo Diesel
Transfer Flow Fuel
2K7 Komfort 241fs
Lots of minor mods
USAF Ret - Nam thru Desert Storm
dobbler98
Ohio
Reflectix bubble foil insulation is what I would recommend. Foil reflects sun and heat away and bubbles provide a cool layer to the interior.
1993 Minnie Winnie
Class C 24'
Chevy 350
Usually pulling one of my toys
Big Katuna
Deland, FL
The skylight over the shower was my peeve. Let lots of light and heat in. They are two layers and you can remove the inside bubble by removing the screws around the molding. Them I cut some of that flexible aluminized foam insulation a to fit and taped it in with aluminum duct tape. Reinstalled the inner bubble. Looks fine, totally balck, much cooler. I also cut pieces to jam up in the skylights/vents.
My Kharma ran over my Dogma.
sharker6
Shelbyville, Kentucky
2" rigid foam board from Lowes, cut to fit and use blue tape as required to hold in place. works well in summer or winter.
2005 Xterra off road 4X4, 2007 26' Aluma-Lite, WD w/ friction sway, Prodigy, Yamaha EF2400, 400w inverter, front carrier w/ rod holders, Dish Network
rushin roulette
Beautiful *cough* Bakersfield
Shade cloth over the outside of the skylight can work wonders. It's easy to cut to size, and cheap enough to replace frequently when you forget to remove it before heading out.
You can find it at just about any plant nursery, and in several levels of opacity.
Busted a U-joint at the crossroads of life.
PatSak
Orlando, FL
I use those 12X12 insulated cushions in each of my skylights. They sell them at Camping World for under $10 each. They work great. For the large skylight in the shower I got one of those thick aluminum door window covers at CW. It fits just right. I use Velcro to hold it on and it is easily removed when I want the light to come in.
2008 Trail-lite 8308S
2006 Dodge Ram 1500, V8,
5.7L hemi engine, 4.10 rear axle ratio
2 Siberian Huskies
zztinker
Bakersfield Ca
sharker6 wrote: 2" rigid foam board from Lowes, cut to fit and use blue tape as required to hold in place. works well in summer or
winter.
This also works for us. Cost about $5.00 and makes all the difference in the world......We just stuff it in without tape........
20003 Aljo Scout 34" TT, 06 Ford 350 PSD,
