RV.Net Open Roads Forum: Using an IPOD to hear music with current built-in speakers
 > Using an IPOD to hear music with current built-in speakers
accsys
Green Cove Springs, FL
Posted: 06/09/08 07:54am Link  |  Quote  |  Print  |  Notify Moderator
Check to see if your current receiver has an AUX button. If so there are AUX input jacks that can be accessed on the back. Mine were PHONO plugs that required an adapter (easily available at Radio Shack) to attach the Ipod.
John & Doris
2006 Four Winds Hurricane 34N, F53 - V10
2004 Jeep Liberty Renegade 4x4 Toad
Roadmaster Falcon 2 tow bar
EvenBrake toad braking system
FMCA F380583, PA, Good Sams
joshjack
Alabama
Posted: 06/09/08 08:05am Link  |  Quote  |  Print  |  Notify Moderator
Actually some receivers only have a "Mode" button that cycles through the different inputs. The only way to be sure is to look at the manual or pull it out and look at the rear (unless there is an MP3-in on the front panel).
J
03 Ram 1500 Quad Cab with Hemi 5.7, HD tow package, K&N Cold Air, B&W Companion + Ball, Prodigy,
1987 Prowler 27.5',
Macbook Pro 17" (Fastest Vista Laptop , iPhone)
Me and the DW and our
2 Dogs: Jackson (golden), Pumba (min-pin)
kmayfield
Cincinnati, OH
Posted: 06/09/08 08:17am Link  |  Quote  |  Print  |  Notify Moderator
llamalover,
I agree with the negative comments re: FM transmitters. I have not had consistent success with them, either.
We have an in-dash AM/FM/CD/cassette stereo in the Winnie. We currently use a cassette adapter similar to this one with great success. If you have this type of an "older" unit with cassette capabilities, this may be an option for you. As stated earlier in the thread, you could look for an AUX input behind your unit, or switch out your current unit for one with an AUX/MP3 jack on the front.
Hope this helps!
Kevin & Janet
2003 Winnebago Adventurer 35U (Workhorse W22/8.1L/22.5)
2002 Jeep Wrangler Safari (Blue Ox/Brake Buddy)
Wherever I happen to park
Posted: 06/09/08 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Depending on your radio (not your I-Pod) there are 4 options
1: I-Pod to FM-over the air (Worst of the choices)
2: I-Pod to FM-Cabled (Much better, also harder to find)
3: I-Pod to Cassette (About as good as #2 requires your radio also play cassettes may not work on all AM/FM/FM/Cassette radios however)
4: Direct connection via a LINE-IN jack or adapter (Only on radios that have that option) This is, by and far, the best way to do it.
My car has a Kenwood AM/FM/FM/Cassette with the ability to remote control a CD changer.. Kenwood makes a "line in" adapter that fits in this same port
My Motorhome has a Pioneer with the same ability,, And, well, it's a different adapter (Line in to Pioneer IP buss instead of Line in to Kenwood) but it's the same function NOTE that the Pioneer allows daisy chaining so I could plug in a multi-cd changer and/or Sat-Radio if I wished and still keep my line in.
Of course not all radios have that
Some even have a front panel I-Pod input jack now days (just need the cord)
So.. What make and model radio do you have.. I can do the research or someone else or you can... Just go to the radio maker's web page, support, manuals, and see if your radio has an optional line in adapter.
Crodad
Lafayette, LA
Posted: 06/09/08 11:31am Link  |  Quote  |  Print  |  Notify Moderator
I agree there are some bad transponders, but the one I have works just as good as a hard wired. In my work van I use a DLO transpod. I have been using this unit for 3 years or more. In my truck (in sig) I have a pioneer Avic Z2 with the IPOD adapter. The sound is equeally good. The Pioneer displays the cuurent song and info and I can use my sterring wheel controls to operate it. What I am really saying is get a good transponder. Here is an example. I am assuming this is for a MH in dash radio. If your talking about the radio in a FW or TT, that's a different ball of wax.
2008 F-250 PSD 4x2 Lariat
2005 Keystone Laredo 29RK
Y-Guy
Tri-Cities, WA
Posted: 06/09/08 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Google Ipod Bluetooth, several options exist. One from bluetomorrow.com looks like it would fit the bill.
Forced Family Fun... They'll thank you later for it!
Have you checked out the new RV.net Blogs?
