mseabee53
Corpus Christi, Texas
Ok let me have it. Please give your input on power jacks. Brand names pros and cons and prices, suppliers and lift capacity. I have a Jay Flight 26BH weight 4685# empty from the fac.
Nascar24
Blackstone Valley, Massachusetts
Hi
I've had Atwoods and Barker Super Jacks, I like the Barker 3500 Super Jack the best, lots of torque, plenty of strength.
Good Luck and Happy Trails
2007 Dodge 3500 4X4 MC,SRW,CTD EB
2004 Citation 29NP
Equal-i-Zer
Yamaha EF2800i
Nascar24 A lengend in my own mind, A Scary thought in someone else's!
LeBout
Eastern Oregon
One inexpensive option is putting your existing jacks up and down with a cordless power drill. I use my Makita and it works slick.
2006 K-Z JAG 25JQ bunkhouse model with rear slide
2001 Ford F150 Supercrew 4x4, 5.4L Triton V8
Prodigy Brake Controller
Eastern Oregon, USA
Check out our 2006 JAG here
2003 Honda Nighthawk motorcycle
skipnchar
Topeka Kansas USA
Most any jack will work pretty well as long as you get one with enough capacity to lift your tow vehicle and trailer tongue. Usually a minimum of around 3,000 lb. and 3500 for larger trailers will suffice. As long as it lifts the combined unit that's about all you can ask for and anything less is totally unacceptable.
swebber
Brunswick , MD
I agree with Skip (again  )that if you buy a brand name jack (Atwood, Ultrafab, Barker) that is the proper size for your rig you can't go wrong. We had a Atwood 3500 on our 27BH Jayco and transferred it to the current 314BHDS Jayco so also consider possible future upgrades.
Enjoy !
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
CampSight
My input is about the same as the others here. Get a bigger jack than you need in anticipation of a possible trailer upgrade. Better to have it and not need it than vice versa.
Mine is an UltraFab 3500. Three bolt installation and one wire to the (+) battery terminal and you're in business. I also use an 18v cordless drill for my stabilizers. No more cranking in 100°F temps for me.
Adam-12
Northern CA
I too want to get a 3,500lb jack. I have a heavy tongue weight, combined with my 2500HD truck bed loaded with stuff. I need a strong jack to lift all of it up when I'm hooking up the WD spring bars etc....
Are all of the jacks "universal" when it comes to fitting them on trailer tongues? If not, how do you know which jack will fit your tt tongue?
Thanks.
2008 Silverado 2500HD Duramax/Allison DIESEL/4x4/CC/Z71
2008 33ft. TT/BH-Super Slider
Parallel Honda EU2000i's
Yaesu 857d
Dipoles/random wire/tuners
Fishing equip.
Quads
Life member: NRA
ALCOHOL
TOBACCO
FIREARMS!
mcoonan
Mendota Heights, MN
The jacks come in different weight capacities, and 2 different tube sizes. IMHO, get the largest weight capacity. You are not just lifting your TT tongue, you are lifting the rear end of your TV. The tube sizes are 2" and 2 1/4". I have the UltraFab 3500, it has the 2 1/4 tube and my trailer had a 2" hole. When I went to install, I used a 1 1/2 drum sander on my drill and made the hole larger. Total install time less than an hour.
Mike
'05 Cherokee 28DD
'04 Expedition w/HD tow package.
Hensley Arrow and Jordan Ultima 2020
JTCR
Central Mass
Go with Barker which is American made and not made in china. Barker backs theirs up even after warrantee ends. Barker 3000 deluxe is a good pick for the money. Good luck
2004 GMC 1500 4x4 Extended cab short bed 5.3 3.73
2007.5 Jayco 328RLS
irish31790
Reading, OH
I purchased the Barker for the same reasons JTCR mentioned - reputation, made in USA. I purchased the 3500 in case I want to go with a heavier TT at some point. I did have one problem - the bolt plate on the Barker was round, but the old, manual jack had a triangular shaped bolt plate. I removed the old jack - 3 bolts, no problem. I took out my shiny new Barker VIP 3500 and slipped it down in the hole. Everything was just fine until the new jack stopped about 1" before the bolt plate rested on the frame. The reason - the Barker's round plate overlapped the tray that the TT battery sits in. I ended up grinding off about 1'4" of the bolt plate and it fit like a glove. Moral of the story - either make sure the bolt plate of whatever you purchase is the same as your existing manual jack or be prepared to perform a little "surgery". By the way, I love my 3500. Between that and the cordless drill for the stablizers, I've almost eliminated sweating from the set-up and tear-down. If I lost a few lbs I could be sweat-free...naaah, that would mean I'd have to give up beer!!
Mr. B
Reading, OH
2007 Jayco JayFeather 29X
Reese Dual Cam Sway, WDH, Progidy Brake Controller, McKesh Mirrors
2004 Suburban Z71
'07 Trips: 7, Nights Camping: 22, Miles Logged on TT: 2,010
'08 Trips: 11, Nights Camping: 33, Miles Logged on TT: 2,189
