badgerfan
Crivitz, WI
Our grandson has requested an apple cobbler or dump cake made in the dutch oven this weekend. Can I use a crockpot liner in the DO? I just want to make clean-up easier. I know someone here must have tried it at some time. I figure that if I kind of tuck it inside the lid, I won't have to worry about it catching on fire. What do you think?
ol'blue
Bremerton, Wa USA
They do have DO liners now. I use heavy duty foil myself. The foil is wide enough to easily fit a 12 inch DO without any seams. WalMart has the foil liners if you want to go that way.
http://www.familycampingchat.com/
kihutson
Daleville, Indiana
I have some of the DO liners but I usually either line it with foil or use the pre-formed foil pans. Both make cleanup a snap.
>> Kathy <<
Bearnkat
Fort Worth, Texas
Hi,
No, I wouldn't use a crockpot liner in a Dutch oven. Some of the sporting goods stores do carry Dutch over liners. I know Sportsman's Warehouse does if you have one close by.
Here's a link to the manufacturer, they do sell over the Internet but you've got to by a ½ case (30 liners).
Disposable Dutch Oven Liners
Good luck and happy cooking!
Chuck & Terry
2005 Pilgrim 281RB-S
2006 Ford F250 Lariat CC 4x2 PSD
My Lap-Band Journey!
DFW/Central Texas Rally - Fall 2008
Chuck and Terry's Pilgrim Adventures
North Texas Camping Association
Lone Star Dutch Oven Society
Twomed
On the road USA
For historic baking we use loaf pans in the oven. You just need to use a couple of 1/2 inch thick stones to raise the pan off the bottom to prevent burning. I guess to make it easy and non-historic you could use your pyrex in there. Works great...has for a couple of hundred years.
Happy Trails
06 Monaco Dynasty
99 Wrangler Toad
US Gear Tow Brake
FMCA 279843
Maintcpo
Central California
Found Dutch Oven Liners in the Camping Section of Walmart Just the other day. Plan to try them out this weekend when I head to the mountains. Hope they work.
Dan, Ret Navy CPO
Minnie The Wife Extraordinare
Chris Our Son the Genius
3 Dogs 1 Dumb , 1 Fat and Stubborn, and 1 new and Adorable
2005 Jazz 2550RL 5er
2003 Dodge Quad Cab Long Bed Cummins 6 shooter
moonchild
Georgia
The dutch oven liners do work as long as what you are cooking does not have too much liquid. They would be fine for the cobbler. Clean up is still easy, just wipe it clean with a paper towel. I have used them a few times but prefer the heavy duty foil. That way, if there are any leftovers (which is rare), I can just fold it up and save it in the foil.
SWMO
Southwest Missouri
I've always used a piece of the wide foil in ours. The area to protect is the side where it tends to stick the worst. The foil will invariably allow some syrup to escape on the bottom, but it has never burned on ours, and being water soluble its easy to clean.
Most of the liners leak a little in my crocks, so?
By the way, if you haven't already, try a spice cake mix for your apple cobbler.
2002 Ford F350 Crew, LB, DRW, 7.3L
Jayco Designer 34RLQS
Joezilla
Mesquite, TX
The link Chuck provided is a good one. We ordered the liners and they fit perfectly inside a 12" DO. I emailed the manufacturer about perhaps getting liners for a 10" DO. He replied that there were no plans in the immediate future for other sizes. Too bad since I just bought a 10 incher.
Joezilla
2007 Ford F350 dually PSD 2WD King Ranch
2007 KZ Montego Bay 36 REB-3 38ft 11in. 5th Wheeler
DocNRed
Ut
I have seen two types of DO liners. One is an aluminum foil type, the other is much like parchment paper. I wouldn't do a cobbler in the parchment. Like many others, I just line mine with heavy duty aluminum foil.
DocNRed
Some heroes wear capes, My heroes wear combat boots!
