RV.Net Open Roads Forum: Dinghy Towing: Jeep JK Flat Tow
Search only in Dinghy Towing
 > Jeep JK Flat Tow
OnTheRoadAgain26
Fla
Posted: 06/09/08 10:59am Link  |  Quote  |  Print  |  Notify Moderator
yes, very interesting:
JK Key-off position = .01 amps draw
JK Key-off position w/underhood light on = .96 amps draw (just a reference)
JK Ign 1st Click = 2.45 amps draw!!! (Also, in this mode there is a relay that cylces every 50 seconds tht briefly draws more current)
JK Ign 1st Click; IOD Fuse Pulled = .17 amps draw
OK, so these are the results which are a little suprising. With the IOD fuse left in place, 2.45 amps/hr x 12 hours = ~30 Amp/hrs which is probably about 1/2 (or more) of the total battery capacity of the JK battery.
Recommendation: If you're flat-towing the JK, lift up the cover on the fuse panel immediately in front of the battery. Lift up the Ignition Off Draw (IOD) Fuse. It is a 60A fuse and it has a holder with white "ears" to help you lift it up.
OnTheRoadAgain26
Fla
Posted: 06/09/08 11:01am Link  |  Quote  |  Print  |  Notify Moderator
yes, very interesting, in other words if I pull the fuse then I am safe to leave the battery poles on ?
roughranger
New Mexico
Posted: 06/09/08 11:33am Link  |  Quote  |  Print  |  Notify Moderator
No first hand experience, but that is what this information would lead you to believe.
02 Granite Ridge 3100 SS
04 Jeep Wrangler Unlimited Highly Modified
00 Ford Explorer XLT 4DR
94 Ford Ranger SC 4x4 Modified
exgman
Placerville, Ca.
Posted: 06/09/08 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
I used to tow with the IOD pulled. As another poster mentioned the more you pull this fuse the more woren out it gets. The last couple of times towing, I didn't pull the fuse and the Jeep started fine. However, I don't think it's a good idea to draw down a standard battery all the time, so I'm probably going to install a cut-off switch.
Dan
06 Country Coach Intrigue
07 Wrangler Unlimited Rubicon
k9eros
San Antonio, TX.
Posted: 06/09/08 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
I pull the IOD fuse and it works great. I will start keeping a close eye on the tightness of the fuse after reading the above information. I have towed about 10,000 miles with no problems as of yet.
I have towed for a short distance without the battery disconnected or the IOD fuse pulled, and if it is more than about 15 miles the Jeep sets a check engine light. The IOD fuse is the way to go, I don't lose any information in the MyGig but it does go to AM when the power is restored.
John
2007 Newmar Mountain Aire 4528, 450 ISM
2008 Chevrolet Silverado LTZ toad
1965 Shelby Cobra 427 S/C
1965 Shelby Cobra 289 Street Car
1969 Camaro 502/T56
2007 Honda GoldWing
2008 Shelby GT500 Convertible
Occasional toads in an enclosed trailer
No_Limits
San Juan Bautista, CA
Posted: 06/10/08 11:33am Link  |  Quote  |  Print  |  Notify Moderator
We tow our 07 Wrangler. Just pull the IOD fuse, see picture. If your coach uses the same bulb for blinking as it does for brake lights and want to use the factory Jeep lights you should also pull the M1 fuse. The M1 fuse will stop the brake light switch on the Jeep from over riding the brake light signal from the coach. If you are interested a company called CooltechLLC sells a great wiring harness that is plug and play.
You won't loose any stored channels in the radio or computer related items. Even the factory pulls the IOD fuse when they ship the Jeeps to the dealer. No need to disconnect the battery.
Rick and Julia...Living Life Without Limits...
2005 Dolphin 5367
2007 Jeep Wrangler Toad.
www.livesafeandhealthy.net
offthewall
New Jersey
Posted: 06/11/08 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
OnTheRoadAgain26 wrote:
I just bough a new 2008 Jeep Wrangler Unlimited 4WD to flat tow behind my MH.
After reading the manual it says to flat tow I need to remove the neg. battery pole / clamp ? Why ?
You really just need to pull the IOD fuse. Check out this newly reconstituted JK towing thread. It explains the why and how of it. I haven't heard of anyone "wearing out" the IOD fuse holder yet on an 07-08 JK. I suppose anything is possible but there is much more in the world to worry about
2008 Gulfstream B Touring Cruiser
 > Jeep JK Flat Tow
