RV.Net Open Roads Forum: Dinghy Towing: Jeep Wrangler as a toad
Search only in Dinghy Towing
 > Jeep Wrangler as a toad
bcampbell
Lanett, Al USA
Posted: 06/09/08 10:05am Link  |  Quote  |  Print  |  Notify Moderator
All Jeeps with part-time 4WD make good toads. Be sure you get a good tow bar. Make sure that it is installed by someone who knows what they are doing.
If you are not going to use the Jeep offroad, I would get a Cherokee, Liberty, or Grand Cherokee. I have towed both a Wrangler and a Cherokee and there is not much difference in towing, but the Cherokee is more comfortable when used alone.
Coachmen Concord
2004 v10 235SO
Jeep Wrangler-toad
FMCA 164852
kmayfield
Cincinnati, OH
Posted: 06/09/08 10:07am Link  |  Quote  |  Print  |  Notify Moderator
RobertB,
Have used our 2002 Wrangler 4WD Automatic as a toad since it was new. In my opinion, this was the ideal toad for us. The Jeep has approx. 45,000 driven miles and probably another 45,000 towed miles (38,000 miles on our current camper) with absolutely NO problems whatsoever!
We tow 4 wheels down with transfer case in neutral and transmission in park as has already been noted. Including brake buddy, connect and disconnect takes all of 5 minutes. We like the ruggedness and the small size of the Wrangler. The size came in handy two weeks ago trying to find a parking spot in downtown Providence during Waterfire!
Hope this helps and good luck!
Kevin & Janet
2003 Winnebago Adventurer 35U (Workhorse W22/8.1L/22.5)
2002 Jeep Wrangler Safari (Blue Ox/Brake Buddy)
Maanpa
Central Point, Oregon
Posted: 06/09/08 11:42am Link  |  Quote  |  Print  |  Notify Moderator
We pull our Rubicon 4 down. The only way I know it is back there is to turn the camera on or on right and left turns. You will be happy with the Wrangler.
Koran & Darlene
Creole, Cajun & Bayou(Our 4 Legged Kids)
2007 Itasca Suncruise 38T
PressurePro/Progressive SP
Steer Safe/Vantage BB/Stowmaster
Hughes Autoformer
2004 Rubicon
Goodsam/PA/F394282
JohnnyT
Goshen New York
Posted: 06/09/08 11:46am Link  |  Quote  |  Print  |  Notify Moderator
Moved from class A forum
RicJones
So. Cal.
Posted: 06/09/08 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
"As said, any 4WD Jeep, manual or automatic, is flat towable with no mods."
Not true, the Patriot cannot be flat towed.
mowermech
Billings, MT
Posted: 06/09/08 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
There are always exceptions.
MOST 4X4 Jeeps with a neutral position in the transfer case can be towed four down. ALWAYS follow the instructions in the Owner's Manual.
CM1, USN (RET)
'94 Dodge 3500 4X2 CTD, Std. cab, LB, 5 speed, 4.10 LS diff., Jacobs Rambrake, 273,000 Miles
'99 Monaco McKenzie 32' triple slide
'95 Tioga 29H Ford-based Class C
Daily driver: '06 Jeep Liberty CRD
Towed: '06 Jeep Rubicon Unlimited
hohenwald48
Hohenwald, TN
Posted: 06/09/08 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
Some Patriots can be flat towed. Depends on drivetrain configuration.
Chris
2001 Monaco Knight
2004 Dutchmen Dorado
1999 Jeep Wrangler
100% Solar Powered Home
When seconds count, the police are only minutes away.
RicJones
So. Cal.
Posted: 06/09/08 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
From the Patriot owners manual:
Towing This Vehicle Behind Another Vehicle (Flat
towing with all four wheels on the ground)
CAUTION!
DO NOT flat tow this vehicle. Damage to the drivetrain
will result.
NOTE: If the vehicle requires towing make sure all four
wheels are off the ground.
JoeG
Henniker, NH
Posted: 06/09/08 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
I have flat towed Wranglers since 2002, including a 13,000 mile trip to Alaska. A Wrangler is a great TOAD. We have toured many gread places with our Jeep which you wouldn't do with many other rigs.
We towed a 2002 Wrangler for about 40K miles and now tow our 2008 Wrangler.
As for a "high step" to get in we added factory steps, so this is a non-issue.
Test drive a new Wrangler, I think you'll love it.
Joe Gilbert
hohenwald48
Hohenwald, TN
Posted: 06/25/08 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
RicJones,
You are correct. I stand corrected. For some reason I was think Commander and not Patriot. Sorry.
Chris
