I have a 2007 Chevy Siverado diesel and I was just wondering...what should the oil pressure be at? Under normal circumstances I seem to be running at 200-300 KPa (Canadian guage). This is without towing. What about with towing- does it change? Never paid much attention to this but I recently thought my guage reading looked low after my last oil change.
Krause wrote: I have a 2007 Chevy Siverado diesel and I was just wondering...what should the oil pressure be at? Under normal circumstances I seem to be running at 200-300 KPa (Canadian guage). This is without towing. What about with towing- does it change? Never paid much attention to this but I recently thought my guage reading looked low after my last oil change.
Did you use thinner oil at your last change? Is it warmer than your last oil change?
I'll leave the metric conversion up to you, but down here in the states, When driving at highway speeds they should run about 60 psi and at idle it is about 25-30 psi depending on temp. When cold, they go as high seen as 80-90 psi. on accelleration.
It's a 2007, still under warranty. If you're worried, take it in to dealer.
2008 Chevy Silverado 4x4 3500 RC/LB 6.0
2007 Chevy GS Conquest Super C 6340DK
2007 Chevy HHR Toad 2LT 2.4
1990 Chevy G20 Cargo Van 305
1967 Chevy Camaro Pro Street 468/650hp BBC
My 70's Show - Tom Kent Radio Network - KLTH - K•HiTS 106.7
from what I have seen, and from dieselplace.com, the duramax runs very low pressure..
2007 GMC DURAMAX,LBZ,4 by Crew, Allison
Magnaflow Turbo Back Exhaust
Predator Tuner
18by9 Helo's on BFG's
5year old boy
3 year old baby girl
Sea ray boat
Wilderness 5th wheel
SandRail
HD WideGlide
FORD Expediton
honda Eu3000
Mine '08 (LMM) generally runs in the low-mid 30's at road speed/temp, regardless if pulling or not.
My '03 (LB7) runs just slightly higher.
Hans, KØHB & Colleen, KØCKB Master Chief Radioman, US Navy -
'04 Prairie Schooner 34FBR Platinum XL Camping Trailer
'08 3500HD Silverado Big Dooley LTZ Go-power by Max & Allie
Mine runs upper end of guage, like 60-70 when cold and starting. It will idle at 25-30. When on freeway at speed in the 45 range unloaded. When loaded in 5th around 45, in 4th 60-70. 02 lb7.
If you want reliable info on the dmax/allison, don't ask the questions on this site. Go to dieselplace.com. Most comprehensive dmax site there is. Do a search there are literally thousands of pages of information. If you had it happen someone on that site has had it happen and they can help you out.
