RV Guy
Lipan, TX.
I find this impossible to believe. I've owned one of these and it ran a 15k A/C plus other power hungry components at the same time.
You were plugging the RV into the generator via a dog-bone or other type of adapter into the 30 amp receptacle of the generator, correct??
If you run two EU2000s don't forget you'll need the parallel wiring kit OR buy one from your dealer. $$$$$$$$$$$$$$$
Good luck with the twins.
Jim
2008 Silverado 3500 D/A CC Dually
2007 Mobile Suites Deluxe - 36SB3
Reese 20K Hitch
Kipor KGE6000Ti generator
Wherever I happen to park
I keep reading threads like this and keep wondering the same thing.....
Why not just take the TRAILER to the dealer and say "Make it Go"
Wayne Dohnal
Banks, OR.
I'm going to guess that the water heater element or electric fridge element was turned on. If not, I agree with the others that said the air conditioner is hosed.
2009 Fleetwood Icon 24A
LinkPro battery monitor
EU2000i generator
Prowler Doug
Northern CA
Make sure your A/C has a hard start capacitor installed. I ran into the same problem had a hard start installed no more problems. The Honda 3000 would not even try and fire my A/C before that. Good Luck Doug.
2005 1500 Hemi Ram
2007 Fleetwood Prowler Classic 240 RKS
hotpepperkid
Chino Hills CA
If its a Fleetwood product I would bet donuts to dollars it does not have a hard start capacitor. Mine didnt. Went round and round with generator company over it. Found out from Coleman Fleewood buys AC's without start capacitors.
hpk
2000 Ford F-350 SRW 4X4 PSD Jayco Super Lite 29.5RKS 5th wheel 50 gal X-ferflow in the bed tank. Banks big exhaust and Stinger kit.
CJW8
Arizona
All these suggestions and the OP never posts back. If my Champion 4000/3500 will run my 15K AC at 5000 feet, the Honda should run his 13500 and then some. Something is wrong with something. Sounds like he is happier with his 2-2K.
2004 F350 PSD FX4 SB CC, Banks Cold Air Intake
18,000 Superglide
2003 37SP Forest River Sierra Toyhauler
2008 Polaris RZR
sagexpman
Loveland, Colorado
That is surprising, my 3000 runs my 15K AC at elevation over 8500 feet....without the carb jet mod
1998 HD Chevy Silverado 2500
- Super Charged Vortec 5.7
- Air Lift Suspension System
- Drawtite WD hitch with 1200# bars
- Drawtite DC sway control
- Honda EU3000IS
2005 Jayco JayFlight 31BHS
mike4947
N. Syracuse, NY
We did extensive testing on gensets and AC's several years ago.
And yes we also found AC units that would either not start or would start and then go into overload on the EU3000i genset.
Temperature plays a part. Th higher the temp the more current the AC will draw. Altitude as well plays a part. As it increases the output of the genset decreases.
Ago of the AC unit also plays a part. Newer high efficiency units draw less amperage in both starting and running.
AND last but not least the other 120 volt draws make a difference as well. When all else fails we'd run a straight heavy gage extension cord directly to the AC unit to guarantee no "outside draws". In that mode well still found two AC units that would not start on a 3000 watt genset, and one that would not stat on the EF3500isb Yamaha that had the extra battery boost for starting.
We never did find an AC unit that would not start on paralleled EU2000i's except if there was an actual problem condition with the wiring/AC/genset that required repair.
As for a soft/hard start capacitor issue, the original poster said the AC started and ran for several minutes and then went into overload. That's not a starting current/capacitor issue.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
Want to sell some of your gear? -
Free Classified Listings on RV.Net
They say you learn by your mistakes, in that case I must be a genius.
RV Guy
Lipan, TX.
In those instances where you were unable to run the A/C with the EU3000, makes me wonder whether that same trailer, when plugged into typical 30 Amp shore power, would blow the 30 amp breakers when the A/c was turned on with other power hungry devices. Like someone said, I'd take the trailer back to the dealer and say, this trailer's A/C has something wrong with it.
Vapor_Trails
Yucaipa, CA
I want to know just how the dealer was 2.25% (99 divided by 44) sure it would work. Even if we rounded up to 3% sure, I wouldn't have bought it on a 97% uncertainty...
OK, sorry, I couldn't resist.
68 Me & DW
93 DD
03 DD
06 F150 Screw 6.5' Bed, 4x4, 5.4, 3.73
04 Tahoe 23RB-GL
Honda EU2000 Parallel Cables
"I hope you like Guinness, Sir. I find it a refreshing substitute for...food." Col. Jack O'Neill, Stargate SG-1.
