RV.Net Open Roads Forum: Travel Trailers: Generator
 > Generator
darlabrad
Southwest
Posted: 06/09/08 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
Does anybody have any experience with a Briggs and stratton 2000 watt portable generator? Sears has them, said they can be linked together if we purchase 2, for a total of 4000 watts, they say very quite. They are made by Craftsman. Want to make sure we are prepared to "rough" it!!!!
Any info would be great!
Thanks again,
Darla
Rollincool
Always Rollin
Posted: 06/09/08 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
Briggs and Stratton... QUIET?!?!?! That's a new one.
2008 Chevy Silverado 4x4 3500 RC/LB 6.0
2007 Chevy GS Conquest Super C 6340DK
2007 Chevy HHR Toad 2LT 2.4
1990 Chevy G20 Cargo Van 305
1967 Chevy Camaro Pro Street 468/650hp BBC
My 70's Show - Tom Kent Radio Network - KLTH - K•HiTS 106.7
darlabrad
Southwest
Posted: 06/09/08 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
So I take it..........NOT quite??? Man, I knew the price was to good to be true!!
Thanks for the info
Darla
sharker6
Shelbyville, Kentucky
Posted: 06/09/08 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
If "they" are the Sears sales staff don't believe it. That engine will drive you off your camp site and everyone around you. It's made primarily for construction.
2005 Xterra off road 4X4, 2007 26' Aluma-Lite, WD w/ friction sway, Prodigy, Yamaha EF2400, 400w inverter, front carrier w/ rod holders, Dish Network
Rollincool
Always Rollin
Posted: 06/09/08 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info
Darla
Darla,
I wouldn't think it would be a bad idea if you guys are out someplace boondocking to use those. That's if you both can put up with the noise. But since most campgrounds and parks have quiet time anyway, you probably wouldn't use it much at those kind of places to begin with.
If they are "cheap" enough, I say buy them if you could satand the noise with no neighbors around. Just think of 2 lawnmowers running right outside your window.
2manytoyz
Central FL
Posted: 06/09/08 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like my very first generator, back in the 80s. Craftsman with a B&S motor. Ran great. Even had a throttle control so it went to idle with no load. Soon as a load was applied, it spun up to full operating speed (3600 RPMs). Yea, it was LOUD.
Unless it's an INVERTER type generator, you won't be bridging them together. A conventional generator uses mechanical methods to generate the AC waveform, and the RPMs determine the frequency.
With an inverter type generator, the waveform and frequency are electronically produced. Consequently, it'll produce a 60HZ sine wave from idle. And since the waveform is electronically created, it's easy to sync it with another waveform produced by a similar generator.
I went to the Sears website. No mention of this being able to be bridged, or an inverter type. So this one will run full RPMs all the time. It also doesn't specify what the noise rating is. That equals LOUD! If they don't want to brag about the dB...
As always, you want quiet, pay for it up front. I bought two noisy generators in the past before getting what I really wanted. Learn from such mistakes, or repeat them yourself, LOL.
Robert
Cocoa, FL
2007 Rockwood TT 2502
Equalizer Hitch
Prodigy Brake Controller
2005 Nissan Xterra
2006 Jeep Wrangler Unlimited
Yamaha EF2400iS
JJBIRISH
Butler, PA, USA
Posted: 06/09/08 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info
Darla
No it means he don't know but it's not a Honda or Yamaha or what ever he has, so it can't be good...
it just may be to good to be true also, but you didn't supply enough information to know...
if it can be coupled with another one it is a inverter generator...
did you bother to ask the model no.???
not everything in-store is on-line, and not everything on-line is in-store...
personally I haven't heard of a sears B&S generator with that capability...
is this it...
* This post was edited 06/09/08 02:01pm by JJBIRISH *
Love my mass produced, entry level, built by Lazy American Workers, Hornet
windriderjr
Massachusetts
Posted: 06/09/08 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
Here we go again...
There is a NPS rule (36cfr2.12) regarding permissible noise levels in NPS CGs. if you read it, you will find two important numbers: the db level and the distance it is measured at. From the rule: "That exceeds a noise level of 60 decibels measured on the A-weighted scale at 50 feet". That's pretty loud but I would bet that the generator you're looking at is louder
My Honda EU3000is produces 54 db at 20 ft (actually, 6 meters but close enough) so by the time the noise gets out to 50 ft, it's more like 20 db (about the noise level of a whisper). Even with that quiet a generator, I've had one neighbor complain in the 2 seasons I've used it (I guess he couldn't clearly hear his constantly barking little dogs).
If you go to sears and check it out, look in the back of the owner's manual for the sound level. It MUST have the level in db and the distance that was measured at.
DW and I in our Gulfstream Amerilite 21MB
Chevy Silverado 2500 HD - Duramax Diesel 6.6L - Allison Tranny
"We can categorically state that we have not released man-eating badgers into the area." - Major Mike Shearer - British Army - Basra, Iraq
MotherOwl
Northwest Louisiana (ArkLaTex)
Posted: 06/10/08 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
Darla, I like having a generator even if I don't use it that often. I hated spending the money for my Honda EU3000is, however I've been glad I did. I've had it places where the noise didn't matter (NASCAR track) as well as places where it mattered a great deal (church parking lot). It's good to know that I can be comfortable using mine anywhere a generator is allowed. Everyone's tolerance for noise is different, but I wouldn't want to listen to a loud generator even if it was powering my own trailer. I've read a number of posts from people who bought one of the cheaper contractor type generators only to end up spending the money later to replace it with something quieter. You might want to rent one of each and compare before buying. You are wise to do some research before buying such an expensive piece of equipment.
Mother Owl
K-Z Frontier 2405
stugpanzer
Illinois
Posted: 06/10/08 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
Tell them you need to hear it before buying it....have them start it.
2008 Rockwood Signature Series 8314SS
2001 Ford Excursion w/V10 6.8L
Reese WD Hitch w/HPDC
Don't forget to visit the RV.Net Blogs!
 > Generator
