RV.Net Open Roads Forum: Tow Vehicles: 2001 Dodge 3500
Search only in Tow Vehicles
 > 2001 Dodge 3500
avalanche
Lancaster, Ca. USA
Posted: 06/09/08 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
Hey There
Can anbody tell me what is required to get the wire harness (7 pin) to the bed for a 5th wheel on a 2001 Dodge 3500. Posting for a friend. Thanks. Jack
The Thermos keeps hot things hot and cold things cold. How does it know?
Jack and Tess
2008 Jayco Greyhawk 32SS
markmassett
Colorado Springs, CO
Posted: 06/09/08 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
On my 04 DRW it had it already on when I bought it used but it looks like they spliced into the bumper plug and ran it to the side where they drilled for the new one.
Mark & Pam Massett, Colorado Springs, CO
2004 Dodge 3500 DRW, 3:73, Prodigy, B&W Turnover Ball, B&W Companion
2006 FR Wildcat 32QBBS
1998 Sugar Sand Tango Jet Boat
dhamblet
Olympia, WA
Posted: 06/09/08 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
There is an adapter you can get that you disconnect the plug for the bumper mounted socket. The adapter plugs in between the male and female connectors and it pigtails up so you can wire in a socket mounted in the truck bed. The kit looks like this
http://store.weekendwarriorgear.com/revefiwhadha.html
but you may be able to find it cheaper.
2005 Dutchmen 35SRV, Pergo floor, 5th Airborne, JT Strong Arm, Kodiak Disk Brakes, Backup camera
2006 Dodge CTD RAM QC 3500 LWB 4WD, Reese 16k, Airlift, Pacbrake, Britebox, 60g aux fuel tank
04 HD Ultra, CanAM 400MAX Quad
Spending my kids inheritance
dhamblet
Olympia, WA
Posted: 06/09/08 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
Oh, and you will need to drill a hole in the bed for the new socket. One of those white bimetallic hole saws and an electric drill will do it.
donhov
near Jackson Michigan
Posted: 06/09/08 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure about your year but if equiped with the camper package from the factory the plug should already be at the rear of the truck under the bumper. It only requires the pruchase of a brake controller and pluging it into the existing plug/harness under the dash near the fuse panel. If not equiped with the camper package then the charging wire and brake controller wires need to be run from the front of the truck while the lights can be run from the rear connector that an above poster mentioned.
2003 Cedar Creek 30RLBS
2007 Dodge 5.9 Cummins Turbo Diesel 325hp/610Tq
4x4 3.73 axles short bed
Inferno Red W/Gold pinstripping
sirdrakejr
Las Vegas, Nevada
Posted: 06/09/08 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from 5th wheels to tow vehicles.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
ib516
Up here!
Posted: 06/10/08 11:02am Link  |  Quote  |  Print  |  Notify Moderator
If the truck has the "camper package", it may already have a harness between the bed and the cab all taped up. Check there too.
2004 Cougar 301 BHS 6580# Dry, 9000# wet, 9600# GVWR)
2007 Dodge/5.9L Cummins 3500 SRW Megacab 4x4/3.73
Hypertech Max Energy
"MEGACASPER" 10100# GVWR, 5200# FGAWR, 6200# RGAWR
PICTURES
ELIM 3000 Gen (still going)
Collision Reconstructionist
ScanGauge2
 > 2001 Dodge 3500
