ohiomom01
Ohio
We have a 2006 Jayfeather 25Z that came with the grill that attaches to the side. Has anyone used their grill like this? We are concerned that using it may mark up the side of the camper or the awning. Let us know if you have use it and how it worked.
Thanks
The Logans
West Virginia
If you're talking about the R-V-Que... we use ours all the time, and love it. It cooks fast, keeps the heat out of the TT, and doesn't need a separate gas supply.
Make SURE that you line the inside with heave duty aluminum foil, or it will be a bear to clean. Cleaning is a snap with the foil... just let the grill cool, then lift out the foil, and throw the mess away.
Happy camping!
Me, My wonderful Wife, 2 Newfies (Molly and Shandie) & 2 Mixes (Max and Sam)
05 Jayco Jay Flight 25RKS
05 Ford F150 4 X 4 Super Crew - 5.4 and 3.73
Aux Oil and Transmission Coolers & Trailer Tow Package
Reese WD Hitch & Dual Cam SC - Prodigy Controller
Hoppers4
Port Orchard, WA
Been using our RVQ for a couple of years now and really like it. Have had it blow out a couple of times under very windy conditions but any gas BBQ would have that problem. We use very low fat burgers and don't generally cook hi fat steaks. Don't really want any flare-ups while we're using it, but other than that, it's works very well for us.
08 Winnebago Sightseer 29R
19Sandie54
AZ
I guess I'll be different...I hated it. Took up space under the awning, was a PITA to clean and doesn't get as hot as our current table top grill. I refuse to use aluminum foil when grilling. I gave mine away and never want another one.
JJ & Sandie
Li'l Jack, Pickles & Bunny the chihuahuas...Chewy, poodle 6/15/95-7/4/08 We will always love you Chooch.
2003 Chevy 2500HD,LT,CC,SB,4x4,Duramax/Allison
2007 Starcraft Homestead 262RKS
larrygranny1
el paso, tx
have one also, didn't like the way it hung(to high) removed the bar on TT and reattached it lower, now the grease doesn't get in our face, we use it offen. has the quick connect for the gas right below where it hangs.
Larry and Linda, we are retired from the miltary and teaching,
F250, 6.4l, 2008 Jayco, 25 ft w/slide
emsdad
Va
I just purchased a Antiqua and I told the dealer to keep the grill. I do not know from experience but I will say I am a FF and 2 things that turn me off are: hot grill mounted on a combustible trailer, and to top it off a quick disconnect that is fed with propane which we all know is very volitle( it actually runs from the tanks in front to the coonection on the side). I personally would rather purchase a grill and have it away from my camper. Just My 2 cents.
sagexpman
Loveland, Colorado
I have the RVQII on my Jayco and have never had a problem with heat or grease on the side of the TT or the awning. As others have said, it doesn't have the same BTU ratings as other tabletop grills. It cooks a bit slower, but I am not in a hurry when I'm camping and I like to cook low and slow anyway.
1998 HD Chevy Silverado 2500
- Super Charged Vortec 5.7
- Air Lift Suspension System
- Drawtite WD hitch with 1200# bars
- Drawtite DC sway control
- Honda EU3000IS
2005 Jayco JayFlight 31BHS
pondputz
Hwy 7 Colorado
I have a 29N Jayco, have used it for the last 3 years, love it
Putz
blog spot
roosterpheasant web site
Bumpyroad
Virginia
sounds to me like a bad idea before it's time.
bumpy
ArnieJ-NH
N. Swanzey, NH
I haven't used mine yet, but plan on using it this month on a trip to Niagara Falls. Thank you for the suggestion of lining the lower unit under the burner with aluminum foil before using. That will certainly help cleanup after splatters and drips! It will also help reflect the heat upward to where you really want it.
Arnie & Mary
2004 4WD Dodge Durango w/5.7L Hemi/3.55/Tow Package
Reese WDH w/Dual Cam, Prodigy Brake Controller
2008 Jayco JayFeather 25F LGT
USAF (Ret) 1962-84 B-52D/G & FB-111A
Ham - N1BAC
My Traveling Web Page
