RV.Net Open Roads Forum: Travel Trailers: Looking For?????
 > Looking For?????
emsdad
Va
Posted: 06/09/08 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a 19" lcd(sharp) with a built in dvd player. I am looking for a mount for it. I would like a munt that will attach to the underside of the cabnet. All the ones I have found is sidewall mount. What are you using? I am still trying to figure out what power jack I want. My trailer weighs 3600#'s. I believe I have a 2" hole. Is ther any way I can tell for sure. There is a little gap on the underside of the jack.
mehwwh
Posted: 06/09/08 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
Re: a LCD mount, check at Best Buy or Curcuit City, both have quite a selection.
Re: power tongue jack, I believe from a previous post that you have a 2006 Starcraft Antigua 215DBB. If that is correct, you would need a 2 1/4" diameter jack.
'03 Silverado 1500, Ext.Cab, Z71 Off Road, 4X4, 5.3L, 3.73 rear, AutoMeter Trans Temp Gauge, Putnam Class IV
'08 Jayco JayFlight G2 23FB, Reese WD Hitch, HP Dual Cam Sway, 800# Trunnion Bars, Barker 3000# Power Tongue Jack
emsdad
Va
Posted: 06/10/08 06:44am Link  |  Quote  |  Print  |  Notify Moderator
Thats correct, 06 Starcraft Antiqua. Thats cool 2 1/4. That means I can get the 3500# jack.
z_i_m
alabama
Posted: 06/10/08 06:52am Link  |  Quote  |  Print  |  Notify Moderator
re lcd mount: ebay has a ton of em.....
http://cgi.ebay.com/Ergotron-Neo-Flex-45-174-300-LCD-Arm-Desk-Mount_W0QQitemZ120269567004QQihZ002QQcategoryZ48656QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
spepi
Mansfield MA
Posted: 06/10/08 11:04am Link  |  Quote  |  Print  |  Notify Moderator
Try this.
http://www.monoprice.com/home/
DW, 2 Teen's, 2 Dogs
05 Chevy Trailblazer (I know...its small)
3.42 Gears
Prodigy Brake Control
Reese 800lb Weight Dist Bars
Dual Cam Sway Contol
2008 Rockwood 2701ss
 > Looking For?????
