I bought a 19" lcd(sharp) with a built in dvd player. I am looking for a mount for it. I would like a munt that will attach to the underside of the cabnet. All the ones I have found is sidewall mount. What are you using? I am still trying to figure out what power jack I want. My trailer weighs 3600#'s. I believe I have a 2" hole. Is ther any way I can tell for sure. There is a little gap on the underside of the jack.
Re: a LCD mount, check at Best Buy or Curcuit City, both have quite a selection.
Re: power tongue jack, I believe from a previous post that you have a 2006 Starcraft Antigua 215DBB. If that is correct, you would need a 2 1/4" diameter jack.
'03 Silverado 1500, Ext.Cab, Z71 Off Road, 4X4, 5.3L, 3.73 rear, AutoMeter Trans Temp Gauge, Putnam Class IV
'08 Jayco JayFlight G2 23FB, Reese WD Hitch, HP Dual Cam Sway, 800# Trunnion Bars, Barker 3000# Power Tongue Jack
