RV.Net Open Roads Forum: Travel Trailers: Levelers??
 > Levelers??
emsdad
Va
Posted: 06/09/08 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
This maybe a stupid question but I bought a set of levelers for my TT. How do you put them on? I knw they stick on but what do I need to do to get them where they read correctly? I cant believe it is that hard but I want some input before I mess up.
Shotgun
CA
Posted: 06/09/08 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
you need to level the trailer first,
both front to back, and side to side
use a 2' level on the floor in front of the door,
once the rig is level, place the little guys where ever you want them.
Hunting is not a hobby. It is much more life sustaining than that.
Dale-pilot, Jeanette-co-pilot
Electrician since 1978
2003 30' Sprinter 5er
2001 Dodge CTD
old guy
Oregon (pronounced Or e gun)
Posted: 06/09/08 11:15pm Link  |  Quote  |  Print  |  Notify Moderator
I think I would use screws to keep them in place, the glue pads that comes with them are not the best. In the heat the levels can sag or slip off.
mosseater
Dillsburg, PA
Posted: 06/10/08 12:13am Link  |  Quote  |  Print  |  Notify Moderator
What I found was the main item (fridgagator) was not level with the floor... or the kitchen counter... or the bathtub. It seems the frig of today doesn`t require quite the absolute (tolerance, not vodka) level of yesteryear (from what I`m reading in my own manual and opinions here) so......... what I did was split the difference.
I took level readings from the counter and the frig shelf and the frig door and the tub drain and the floor. Since they were pretty close, I averaged them and biased it to the counter (I know, I`m sick) figuring the frig would be close enough and I didn`t want counter spills running to the back of counter and down the wall, I`d rather have it coming towards the front so I can clean it up. Once you level the trailer to where you want it, carefully and accurately place the levels on the front corner of the trailer exactly level. Keep in mind the trailer will tip a little toward the super slide when out. You can fine tune with the jacks if necessary as long as you don`t get carried away. I add Lynx-blocks-per-line reading the bubble on the low side and fine-tune it in with the slide out and jack pressure. Just play around with it til you get used to it.
It`s probably not as important as it sounds, so have fun with it. Makes a great excuse to drink beer and sound important while the DW admires from affar.
Sunset Creek 298 BH
chi6488
florida
Posted: 06/10/08 04:35am Link  |  Quote  |  Print  |  Notify Moderator
I have two bubble levelers as well to attach to outside of TT. Why couldn't I just use a level and attach the levelers to the TT. If the bubbles are level then the TT is level.
2009 Jayco Eagle 324BHDS
2008 F250 King Ranch 4wd
2005 GLacier Bay 2670 Cat
Hornet28BHDS
Parker, PA
Posted: 06/10/08 04:37am Link  |  Quote  |  Print  |  Notify Moderator
Get your TT level and then place them on it. We have ours on the front streetside corners, that way we only have to look at one place when we are leveling. Good luck!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
Bumpyroad
Virginia
Posted: 06/10/08 04:40am Link  |  Quote  |  Print  |  Notify Moderator
I'd check the level on the "floor" of the freezer. once it is level, then apply the bubble level indicators.
bumpy
z_i_m
alabama
Posted: 06/10/08 05:36am Link  |  Quote  |  Print  |  Notify Moderator
if your unit is not level side to side......just get the reading off a 2 foot level with your sticky with it and make note where the bubble is.......i.e. 1/2 marks off..........then apply your sticky bubble in the same reading as you read it inside.........
pete42
Jamestown, Ohio
Posted: 06/10/08 05:49am Link  |  Quote  |  Print  |  Notify Moderator
I placed mine, small ones on the A frame.
I don't walk very well so any thing I can do to keep from walking I do.
The front to back one is easy to see while cranking the tounge jack
Jnbaun
Ridley, PA
Posted: 06/10/08 07:33am Link  |  Quote  |  Print  |  Notify Moderator
I followed the advice of others here and set a level in the freezer and used that to level the trailer....WRONG. After I did this I stepped back to look at the trailer and found it to be wayyyyy off. I took a good look at the freezer floor and found that to be a bit wavy so there was no way to get an accurate reading. Instead I set a level on the floor after checking several different areas to make sure they were all the same.
John
Wife - Renee and 2 boys ages 12 and 7
 > Levelers??
