I just ordered a roll of the "one step".Besides the front and rear seals.What are some other areas i could use it on that would help. thanks for any input.
If you have a skylight over your tub, definetely seal it with eternabond. Make sure the eternabond contacts the skylight material and bridges all the way to the rubber roof.
The factory Dicor material does not adhere well to the skylight material and is prone to leaking.
I covered everything that had Dicor on it with the eternabond tape.
John U
Midnight pumpkin
2003 Dodge Ram 2500, HEMI, 2WD, 3.73 gears, 5speed Auto
Prodigy Brake Controler
Reese Dual Cam HP
I used a bunch of Eternabond on my roof rebuild. It is so sticky, I intentionally did not use it around fixtures I might some day want to remove, such as the roof vents. I did use it around the skylights since they have such a large perimeter and they are not centered on the roof. The roof I added has a gentle curve, so water will flow away from middle. If you think your skylights (if you have any) could stand to be replaced in the next few years. I would leave the Eternabond off.
88 Gulf Stream 34' Sun Vista, Ford 460, Edelbrock Perfomer carb, Thorley headers
Ford F-250 crew cab 4X4, 6.0 turbo diesel complete roof rebuild
daughter 15, son 11
US Army Desert Storm vets (both of us)
left: The Ol' Gal right: DW with White Lightnin'
I covered all seams, screw heads, joints, skylights, vent surrounds, everything. Yes, it is a pain to remove, but I haven't had to yet and no leaks is a fine thing.
