RV.Net Open Roads Forum: Travel Trailers: Eternabond question
 > Eternabond question
sprinterowner
tyngsboro,ma
Posted: 06/10/08 04:54am Link  |  Quote  |  Print  |  Notify Moderator
I just ordered a roll of the "one step".Besides the front and rear seals.What are some other areas i could use it on that would help. thanks for any input.
Keystone Sprinter 311 BHS
2007 Silverado 2500HD "classic" CC Duramax/Allison Greystone metallic
tnt4utvols
Tennessee
Posted: 06/10/08 05:55am Link  |  Quote  |  Print  |  Notify Moderator
I applied it to every seam on top (around vents, AC, & antenna).
GO BIG ORANGE!!!
Topsail Hill Cult Member
Topsail Hill Site Photos
Topsail Area Attractions
Midnightpumpkin
Concord Twp, Lake County, Ohio
Posted: 06/10/08 05:57am Link  |  Quote  |  Print  |  Notify Moderator
If you have a skylight over your tub, definetely seal it with eternabond. Make sure the eternabond contacts the skylight material and bridges all the way to the rubber roof.
The factory Dicor material does not adhere well to the skylight material and is prone to leaking.
I covered everything that had Dicor on it with the eternabond tape.
John U
Midnight pumpkin
2003 Dodge Ram 2500, HEMI, 2WD, 3.73 gears, 5speed Auto
Prodigy Brake Controler
Reese Dual Cam HP
2007 Rockwood 8315SS Travel Trailer
Loaded Weights:
Trailer Axles 6640#, Hitch Wt 920#
Combined Gross Wt, no passengers, 13,855#
ScottnSherrie
Augusta, GA
Posted: 06/10/08 05:59am Link  |  Quote  |  Print  |  Notify Moderator
I used a bunch of Eternabond on my roof rebuild. It is so sticky, I intentionally did not use it around fixtures I might some day want to remove, such as the roof vents. I did use it around the skylights since they have such a large perimeter and they are not centered on the roof. The roof I added has a gentle curve, so water will flow away from middle. If you think your skylights (if you have any) could stand to be replaced in the next few years. I would leave the Eternabond off.
88 Gulf Stream 34' Sun Vista, Ford 460, Edelbrock Perfomer carb, Thorley headers
Ford F-250 crew cab 4X4, 6.0 turbo diesel
complete roof rebuild
daughter 15, son 11
US Army Desert Storm vets (both of us)
left: The Ol' Gal right: DW with White Lightnin'
sprinterowner
tyngsboro,ma
Posted: 06/10/08 06:31am Link  |  Quote  |  Print  |  Notify Moderator
Is DICOR the grey putty like stuff?
Hornet28BHDS
Parker, PA
Posted: 06/10/08 08:08am Link  |  Quote  |  Print  |  Notify Moderator
I would cover every visible seam on the roof with the Eternabond.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
david_42
Oregon
Posted: 06/10/08 09:56am Link  |  Quote  |  Print  |  Notify Moderator
I covered all seams, screw heads, joints, skylights, vent surrounds, everything. Yes, it is a pain to remove, but I haven't had to yet and no leaks is a fine thing.
sprinterowner
tyngsboro,ma
Posted: 06/10/08 10:42am Link  |  Quote  |  Print  |  Notify Moderator
good advice thanks.
morsecodeham
MA
Posted: 06/10/08 11:52am Link  |  Quote  |  Print  |  Notify Moderator
With the exception of the A/C, I put eternabond tape across the front seam and around ever place the manufacturer cut a hole in the roof.
2005 Jayco Jay Feather Sport 186
2005 Ford F-150 XLT Long bed 4.6 V8 3.55 axle
Reese WD & HP Dual Cam Anti-sway
Mike Up
NW Indiana section of Chicagoland
Posted: 06/10/08 11:59am Link  |  Quote  |  Print  |  Notify Moderator
If your skylite does develop cracks, how do you remove the eternabond??
Have a good one.
2008 Eureka Copper Canyon 1312
13'x12' Tent
2007 Starcraft 2406 Exterior
2007 Starcraft 2406 Interior
2008 Ford Explorer Sport Trac 4.6L V8 4X4
292 Hp, 300 lbs torque, 7000 lbs towing, 730 lbs hitch
Tow-N-See Convex Mirrors
