joebloe
Rockford, Illinois
Every 20 minutes or so the water pump cycles on for less than a second when not in use. I assume it's losing pressure somewhere via a very slow leak. Is this right?
K&R
Oklahoma
Yes
sharker6
Shelbyville, Kentucky
Built-in check valve prevents back flow within the water pump, it doesn't mean you have an external water leak. Changes in night temps and day temps will also change the pressure and cause the pump to activate. Mine comes on a few times a day, it's not a big deal. The pump could probably be at fault unless you have water on the floor somewhere.
2005 Xterra off road 4X4, 2007 26' Aluma-Lite, WD w/ friction sway, Prodigy, Yamaha EF2400, 400w inverter, front carrier w/ rod holders, Dish Network
Itchey Feet
Wyoming
Check and make sure that there is not a small drip from one of the faucets, even a small drip will cause a pressure drop and cause the pump to cycle. (If you have an outside shower check it too). JMHO
My feet are fine as long as they are traveling.
kknowlton
Wisconsin Border Country, IL
It's possible it's just "catching up" - if you run water for just a second or so, the pump may not run then, but will "catch up" on the pressure somewhat later. The pump will be less likely to do this if you add an accumulator. We've added accumulators to both our trailers and were happy we did; the pump (and noise) runs less often.
pmfinnegan2
S.E. Michigan
Could be air in the lines as well
pmfinnegan2
1998 Dodge Ram 1500 Sport
318 5.2L V-8, 3.92 Rear end
HD Transmission Cooler
2006 Max-Lite 24RS
Equalizer Hitch, Prodigy Brake Controller
Wife, 6 year old Daughter, and 2 year old son
BLDMAN
Missouri
If it's every 20 minutes or so I would suspect a small leak somewhere. I'm certainly not an expert but when I experienced a similar pattern of cycling I had a very small leak in the h2o line going into the toilet. Never would have known it otherwise. It was in the connectors between the lines.
Jeff and Barb two sons Jeremy and Jared one daughter Heidi one grandson Gabe
Two Labrador Retrievers Shadow and Otis and her majesty, Miki the Boston Terrier
2006 Fleetwood Prowler 275CSK Fifth Wheel
1999 F350 PSD dually
Hornet28BHDS
Parker, PA
I would say that it is just the pump building pressure back up after losing it.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
emaav
Hillsboro, Oregon
Could also be the diaphragm, we have a crack in ours, pump will cycle about every hour or so. I just turn it off at night. Try and tighten up the screws on the front of the pump, maybe they backed out a little.
Me (Eli) 1972
DW (Monique) 1974
DS (Alex) 1996
DD (Amanda) 2002
1997 GMC Safari
2003 Jayco Kiwi 21C
JJBIRISH
Butler, PA, USA
for the pump to activate the pressure has to drop... if you haven't used any water the pressure shouldn't drop enough to cycle the pump... meaning there is something leaking... as stated in a earlier post the check valve could be leaking water back into the FWT or there is a leak that is worth tracking down... both scenarios are pretty common...
Love my mass produced, entry level, built by Lazy American Workers, Hornet
