RV.Net Open Roads Forum: Travel Trailers: Do I have a leak?
 > Do I have a leak?
Neilm_108
Calgary, AB
Posted: 06/10/08 09:08am Link  |  Quote  |  Print  |  Notify Moderator
JJBIRISH wrote:
for the pump to activate the pressure has to drop... if you haven't used any water the pressure shouldn't drop enough to cycle the pump... meaning there is something leaking... as stated in a earlier post the check valve could be leaking water back into the FWT or there is a leak that is worth tracking down... both scenarios are pretty common...
Agree - you need to find a leak. Pump shouldn't cycle on a regular basis at all.
joebloe
Rockford, Illinois
Posted: 06/10/08 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
Lots to think about! Thank you for all the responses.
I have been all over the trailer except one space under the fridge and have found no leaks. Although we do have the outside shower, it's never been used or opened, though I guess that doesn't mean as much in a four year old trailer. That's where I go next.
Land Cruisers
Waterloo, Ontario, Canada
Posted: 06/14/08 02:59am Link  |  Quote  |  Print  |  Notify Moderator
Don't forget to check your water heater, could be the drain/anode rod leaking around the threads on the outside too. That was my solution when I had the same thing happen, ended up wrapping a bit of teflon tape around the threads, re-tightening, and no more problem.
2008 Jayco Eagle 325BHS
2006 Dodge Ram 3500 MegaCab 4X4, Cummins
2 kids age 6 & 8, and a 6 year old golden retriever...
chi6488
florida
Posted: 06/15/08 07:34am Link  |  Quote  |  Print  |  Notify Moderator
Leak
2009 Jayco Eagle 324BHDS
2008 F250 King Ranch 4wd
2005 GLacier Bay 2670 Cat
2milesup
Leadville, CO
Posted: 06/15/08 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
The title of this thread reminds me of a stay in a motel down south a few years back. Called the front desk and said, "I got a leak in my sink." The guy said, "Go ahead."
Jerry, Lori and Parker the Chocolate Lab
2005 4Runner 4.0 4X4
2007 Dutchmen Lite 18B
Reese Pro Series SC, Prodigy, Honda EU2000i
 > Do I have a leak?
