go leafs go
Ontario, Canada
Just wondered if its ok to keep the trailer hooked to truck for a two night stop?
Me -older, wiser but still a leaf fan
The Boss tells me my team sucks
The Bosses Boss 12 and a happy camper, go Argos
little chicken shuit-zu
sharker6
Shelbyville, Kentucky
Sure, I do it. Just don't run down your truck battery.
2005 Xterra off road 4X4, 2007 26' Aluma-Lite, WD w/ friction sway, Prodigy, Yamaha EF2400, 400w inverter, front carrier w/ rod holders, Dish Network
rwmmdj
Georgia
We've done it before also.
marly
Yutan, NE 68073
We do it at times. You are hooked up all day towing and bouncing, what could a calm stop over hurt?
Crazy_2
New Maryland New Brunswick
Take some of the weight off your Tow Vehicle using your tongue jack,
Just don't forget to crank it up before you drive off.
03 Nissan Xterra
Travel Star Sport XLT 24 FQB by Starcraft 3570 LBS Dry
Prodogy EBC, Reece Dual Cam WDH
kknowlton
Wisconsin Border Country, IL
I've also heard that you should disconnect the pigtail between TV and TT when stopped (assuming you're hooking up to electricity in the campsite). We have done a staying-hitched overnight once and it worked out fine. I agree to put the tongue jack down & relieve the TV of the extra weight while camped.
wayne_tw
South Dakota/Georgia
Of course you can, why would you even think you can't keep the truck hooked to the trailer? The trailer and truck have been bouncing on the road all day, and now while stopped, it can't be connected? Ever stop while connected and eat, maybe linger a while at a point of interest enjoying several hours or more at the site? Should the trailer be disconnected for that?
stugpanzer
Illinois
I have done this with no problems. Also, I put the tongue jack down, but not to relieve the pressure on the TV but to help stabilize the TT.
2008 Rockwood Signature Series 8314SS
2001 Ford Excursion w/V10 6.8L
Reese WD Hitch w/HPDC
Don't forget to visit the RV.Net Blogs!
Hornet28BHDS
Parker, PA
It's absolutely fine. Good luck!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
skipnchar
Topeka Kansas USA
go leafs go wrote: Just wondered if its ok to keep the trailer hooked to truck for a two night stop?
If you have a Ford for a tow vehicle you will have no problems. If you have most other types of tow vehicles, you will not have any problems as long as you unhook the electrical umbilical cord so you don't run down your battery on the tow vehicle. Ford uses a relay to isolate the two unless the ignition key is turned on but most others use only a fuse and it IS possible to flatten your battery on the tow vehicle.
There SHOULD be no reason you'd need to take any weight off of the tow vehicle since it seems to support it just fine (or I HOPE it does) when you're going down the highway with it. It'll do just as well sitting still as when bouncing down the road. You MAY Need to use the tongue jack to level the trailer, however, and THAT is necessary to keep from damaging your fridge.
Good luck / Skip
