RV.Net Open Roads Forum: Truck Campers: Changing DRW to SRWs
 > Changing DRW to SRWs
Page of 5
hopak
Point Reyes Station, Ca. / Crestone Co.
Posted: 06/10/08 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Would like to change over to 19.5 SRW. Seems like I should be able to "just" remove the stock wheels (and maybe get a new box but at least remove the outriggers) and replace with Visions or Ricksons. Or is that too simple and there is some trick to it I'm not aware of?
2002 Dodge,diesel, 3500,4x4,auto/od,ex,cab, 01 Bigfoot 25c 10.5
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/10/08 07:43am Link  |  Quote  |  Print  |  Notify Moderator
If you want to change the fronts, you'll need to either remove the DRW adaptor hub, or change out the stock DRW hub for a SRW front hub, depending on how your front axle's hubs are made.
On the rear, remove both wheels and the spacer. If your wheel studs have a long shoulder on them, they may need to be changed to studs with a shorter shoulder, but they may work fine as-is too. You may or may not need new lug nuts for the new wheels.
If you're swapping to taller tires, you may want to change out the axle gear ratio to match the new tire height. This is a significant expense on a 4x4 (around $1500).
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
jjohnson1179
Girdletree, Maryland
Posted: 06/10/08 07:45am Link  |  Quote  |  Print  |  Notify Moderator
You are going to have to get a wide rear wheel because the drw rear is not as wide as a srw rear is
JIMMY JOHNSON
93 Ford F-250 V8 5.8
1987 LANCE 980 11.3
AMSA# 52
TRUCK CAMPER MAGAZINE
FEET IN THE SAND COLD BEER IN MY HAND
camping man
Central Fla.
Posted: 06/10/08 07:53am Link  |  Quote  |  Print  |  Notify Moderator
Post this at one of the diesel forums, their's folks going back and forth all the time trading parts with one another.
05 Dodge 2500 Quadcab CTD NV5600/3.73rears
97 27ft.Sprinter 5er
Website
Boatycall
Tacoma, WA
Posted: 06/10/08 11:16am Link  |  Quote  |  Print  |  Notify Moderator
If it's the truck in your sig, you'd likely still be able to haul the camper in your sig, but you'd be really close to an E rated tire rating. I'm not playing the weight poice game, I'm just curious. Taking a DRW to a SRW sounds kinda like breast reduction surgery--why would you? ;-)
'01 F350 CC DRW 4x4,4" turbo back exhaust,SCMT,pyro tranny temp& boost gauges,4.10 gears
'03 Arctic Fox 1140,4 Trojan T105s,1.5kw inverter,icemaker
92 YJ 35's,6" lift,ARB lockers,Ford 8.8, 8k winch
Honda 400ex
10k 24' toybox
221, 221, whatever it takes.
Hey there
Pendergrass, GA
Posted: 06/10/08 11:27am Link  |  Quote  |  Print  |  Notify Moderator
What about the fenders? Are they individually removable or does the whole bed have to be swapped?
Kurt
2001 Silverado 3500 DRW CC LB 6.0
1993 Lance Squire Lite 150 (8'6")
2001 Fleetwood Caribou 11J (11'6")
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/10/08 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
He'll have plenty of weight rating with the 19.5's.
pjay9
Tacoma, WA
Posted: 06/10/08 11:59pm Link  |  Quote  |  Print  |  Notify Moderator
OR get a Smarty JR and do it electroically to match the tire size to speedo, about $495 Capt PJ
2005 Lance 1161/2004 Dodge CTD 3500 Dually
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/11/08 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
I was talking about the actual final drive ratio, as it relates to engine rpm, towing power, and fuel efficiency. All of these factors are affected by changing tire height.
Superlift (the 4wd suspension lift company) sells a little electronic adjuster for speedometers for about $150.
BoilerEE
Anchorage, AK
Posted: 06/11/08 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Other way around, right? A DRW rear end is wider hub to hub than a SRW rear. If you tried to put a dually inner wheel on a SRW truck I'm pretty certain it would hit the springs, so that means a low-offset SRW wheel will make the rear track too wide.
'07.5 GMC 3500 / '04 S&S 11DB
Page of 5
