semopetvet wrote:
Hope someone is still monitoring this section. I've been offline for a week.
I unhooked the negative cable from the battery, left the rv plugged into shore power and the 12 volt lights still worked - so does this mean the converter is ok? as far as I can tell the fuses are ok.
I checked the battery c a voltmeter and it read somewhere between 11-12 volts both when not hooked up to shore power and when hooked up to shore power. ( the engine battery read 12 volts). I put a trickle battery charger on the house battery and within 1 minute it read fully charged. the fluid level is ok.
I tried to use the house battery to start the generator and it would not (Note: when I do this the LP detector starts beeping until I reset it - don't know what this means). when I push the button to tap into the engine battery, the generator starts easily.
Does this mean that most likely the house battery is bad?? I plan on taking it to Autozone to have it tested tomorrow.
thanks again for the advice. chuck
