RV.Net Open Roads Forum: Travel Trailers: Toilet repair
 > Toilet repair
Dandy
NorthEast
Posted: 06/11/08 06:18am Link  |  Quote  |  Print  |  Notify Moderator
I think the pull levers on my toilet are backwards.
All the previous trailers I owned always had the first lever so you could put water in the bowl and the second lever opens the flapper.
I just noticed this the other day, but the first lever opens the flapper and the second one puts in the water.
If this is wrong, how do I fix it?
Chevy 1/2 Ton Crew Z71 / 3.73 / 5.3L
Rockwood 8317 SS (Yes, it's a 1/2 ton pulling it)
Reese WD System with HP Dual Cam
Primus Brake Controller
Factory Receiver Hitch
McKesh Mirrors
kraushad
Eastern Panhandle, WV
Posted: 06/11/08 06:23am Link  |  Quote  |  Print  |  Notify Moderator
Mine is different.
BUT, does your second handle always trigger the first? In other does the way yours is currently setup mean that you cannot add water without also opening the flapper?
If not, I wouldn't worry about which did what.
If so, I wouldn't have a clue how to reverse it as a DIY project.
Dirk
Myself (34), my Wife(32), and "The Boy"(3)
06 GMC Sierra 1500 Crew Cab, 5.3L V8, 3.42rear
05 30QBSS Trail-Cruiser, Prodigy BC, Reese Dual Cam W/D
SidKaye
Mt Dora Florida, Montreal QC for the Summer
Posted: 06/11/08 06:29am Link  |  Quote  |  Print  |  Notify Moderator
What brand and model?
2003 Dodge Ram 3500 SLT,48RE, 4:10,Cummins HO Diesel,Quad Cab,LWB,SRW,PacBrake,Prodigy, X-Monitor Gauges,Line-X,Bedsaver
2002 Excel,Ltd,30RGW,Hughes Autoformer,Honda Eu1000i, Hughes Direcway HN7000S, Satmex5,
http://www.kayepics.com
Dandy
NorthEast
Posted: 06/11/08 06:36am Link  |  Quote  |  Print  |  Notify Moderator
When you pull the second handle the first goes with it.
So you see my problem. It is impossible to fill the bowl with water using the handles.
I have no clue on the model. I will try to get it tonight and re-post.
Someone told me it may be as simple as reversing the levers inside the toilet.
z_i_m
alabama
Posted: 06/11/08 06:41am Link  |  Quote  |  Print  |  Notify Moderator
does the handle raise up to fill bowl?........
popscolly
North Carolina
Posted: 06/12/08 06:53am Link  |  Quote  |  Print  |  Notify Moderator
From the description, the toilet sounds like it's a Thetford Aqua Magic. That being the case, the levers are reversed. The first thing to do is open the flap and stuff a plastic bag into the hole. There will be springs and things that will jump down that hole. There's several Phillips head screws under and around the upper assembly. After these are removed, the upper assembly lifts off. Be careful because the actuator arm is the first assembly with parts that might jump down the hole. Then, you will have access to the lever assembly. It will be a case of repair or replace. While your at it, replace the ball valve. It's the first part at the water line. Hope this helps and best of luck.
The Colliers, Michael and Linda
2000 Gulfstream Innsbruck 30 FKD
2003 Ford F150 Supercrew Heavy towing
Chase, Swayze (Tibetian Terriers)
and Byshe (Papillion)
 > Toilet repair
