The Beave
Georgetown TX USA
This morning I happened to notice a Yellow jacket entering the outside vent behind the refrigerator. When opened the vent I found we are providing habitat for both Yellow jackets and mud dabbers.
The vent does not provide any screening material, just a series of slots large enough for the wasps.
Would placing screen material behind the vent imped air circulation sufficient to upset the refrigerator operation?
Also found the critters in my 50 amp power outlet.
The Beave
30' 1997 Beaver Monterey
(The shortest DP we could find)
2005 Honda CR-V
Remco surge brake
Don Don
Pleasant Grove, AL {Suburb of Birmingham}
Rv parts places and Camping world sell screen for fridges and furnaces. Just pick one up.
Rollincool
Always Rollin
That's one reason to check everything once a week during the warm months.
Be careful with the yellow jackets, they'll sting the hell out of you. Especially the little ones that make the paper nest. (which is more than likely what those are). Mud daubers won't sting you. They just make mud pies! (well actually storage tubes for food).
Like Don Don said, put up screens, ... after you eliminate YJ's. Clean out any Dauber tubes.
2008 Chevy Silverado 4x4 3500 RC/LB 6.0
2007 Chevy GS Conquest Super C 6349
2007 Chevy HHR Toad 2LT 2.4
1990 Chevy G20 Cargo Van 305
1967 Chevy Camaro Pro Street 468/650hp BBC
My 70's Show - Tom Kent Radio Network - Kā¢Hits 106.7
Horsedoc
Dixie --- N. Georgia
I had some scrap fiberglass screening left over from redoing a door and used it and a hot glue gun to solve the bug problem. Cut it to fit the inside of the door and laid down a short run of glue and pushed the screen into it. Worked it around the edges and on the cross pieces.
horsedoc
2008 Damon Essence
2003 Honda Element
Blue Ox tow
Gas Man
Winston-Salem, NC.
We have used screen on the inside of the refrigerator grill for years with no adverse effect on operation. Clean out what you can find as far as nests or dirt tubes and while the grill is out form fit aluminum screening to the inside (fiberglass screening is a little too flexible)and secure with generous spots of clear silicone adhesive sealer, allow to cure for several days before installing and driving. The little buggers can get in the exhaust at the top of the coach too, that project takes a little more time to do but same principle. The furnace and hot water heater stainless covers can be purchased at most camping stores.
D. Brown
Winston-Salem, NC.
2004 Damon Daybreak 3270F
Life's a race. Keep your motor runnin and burn rubber every now and then!
Chuck&Gail
In the Colorado Mountains
I bought some for TT water heater and fridge on line a few years ago. They work great. Had one on furnace for many years.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
Anml_341
Ontario, Canada
I was advised years ago to hang a pet flee collar inside the refrigerator vent to stop yellow jackets from moving in. I did this and we have not had problem. Whether or not it was the flee collar or just plain simple luck I do not know. Cheap & easy fix if that is what is keep them away. That reminds me, I should more than likely change it as it has been over a year now.
Frank Spence
Ontario Canada
Member: Explorer-RV Club (Canada)
Member: FMCA #F275853
We invite you to check out our websites:
http://flspence.blogspot.com/
http://rvworkshops.blogspot.com/
http://fourseasonsrving.blogspot.com/
Fred_n_Jo
central MO, USA
Twice a year, spring and fall, I buy a large dog flea and tick collar and cut it in half. Half goes into the water heater compartment and the other half goes into the outside access to the fridge. I was told this would prevent spiders from building in the fuel tubes and other critical areas. If it keeps out yellow jackets then that's good also. Maybe I should put one in my power outlet by our RV pad. After our last three week trip I went to plug into the outlet and found a paper wasp nest started.
2006 F350 6.0 psd xcab lb srw
2008 Carriage Cameo F34CK3 5th
garry1p
Broken Arrow, OK, USA
Flea collar works I slipped on in the HW compartment after red wasp set up house keeping and a few days later they were gone.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
jess33
Lawton, Oklahoma
garry1p I see you are also in Oklahoma, will flea collars also keep the mud dobbers away? That is my big problem.
