hathawayb
Colorado Springs, CO
Hi everyone, I have a 2002 Southwind, Class A, 36R. My lights for the outdoor and light over the chair and entry light seems to have blown a fuse. I have checked the fuse box under the hood that holds all the RV fuses and they are all ok. Do you suppose it is a fuse located by the brake panel that blew out? It is on a FOrd V-10. It seems to be hunt a good luck on this one! Thanks, Bill
enblethen
Moses Lake, WA USA
These lights should be in the DC coach distribution panel not the chassis fuse panel.
It should be located near your converter. Some are behind a small metal cover.
Bud
Suzuki XL7 pushing Pace Arrow
pulsar
Lewisville, NC
Moved from Forum Technical Support to Tech Issues.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
teb1272
Memphis
Right-that fuse should be inside the coach in the 12 volt distribution panel for the "house". Under the hood you generally have only the fuses for the truck on which the house is mounted.
hathawayb
I checked the house fuses in the front hood and all proved to be ok! I guess I will keep looking. Kind of hard not to have a light outside or inside by the door right now. Thanks, any other ideas. I have not checked the fuse pannel down by my brake yet. I have to take my "make my body into putty" pills.
mchero
Concord, NH
I think your looking at the wrong fuse panels. I'm sure another Southwind user will chime in. My pace arrow has a 12VDC fuse panel under the bed and another 12VDC panel in the electical panel.
The fuse panels under the hood and under the dash are gor the chassis, parking driving lights, insterment cluster wipers and such.
Robert McHenry
Concord, NH.
1993 Fleetwood 36' Pace Arrow
Cummins 8.3l Turbo 300hp (uprated)
Allison 3060 Trans
http://dieselrvowners.com
T&A
SE Michigan
The fuse should be located near the converter. Mine is located at the edge of the bed. Sometimes located in the closet. Usually a square metal panel about a foot square that hums and will usually have a fan. Often the same panel that contains the 120V circuit breakers. Open the panel and you should find the fuses (automotive type). Good Luck.
Terry
Terry & Amy
2004 Hurricane 30F on P32 Workhorse Chassis
2002 Jeep Grand Cherokee
hathawayb
Ok, thanks to all, I found the fuse box in the bedroom under the TV. Duh! Old age must be setting in. Thanks again to all. Bill
tallyo
Fort Myers,Florida
I had a Damon with a V-10 , along with the fuse box inside the MH(hidden in the bedroom) ;there were two fuse boxes under the hood, one had circuits for the coach parts also. Was even a reset button for items such as refrigerator ignition etc.
Never say never folks or never say there shouldn't be. One never knows with an RV where the manufacturer will "tuck" things.
Tallyo
2007 Winnebago Adventurer
W-24, 6 spd Allison
Saturn VUE w/ Brake Buddy Vantage
Drinks-6, Eats-4, Sleeps-2
Semper Fi
