RV.Net Open Roads Forum: Class C Motorhomes: batteries/charging
 > batteries/charging
muskrat001
Littleton, co
Posted: 06/11/08 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
help,
new to rv's. I have an 88 honey. It has a Onan generator with internal switch. I have the usual battery under the hood and one under the back bed hooked to the generator. Does the alternator charge that battery? Does the generator have to run to charge the battery, or do I have to purchase an aftermarket charger and charge between trips.. sorry for simple question just new... thank you
Home Skillet
Pearland Texas
Posted: 06/11/08 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
The vehicle's alternator will charge both batteries when the generator is off.
When the generator is running, the invertor will charge the RV's battery.
Welcome to the fun world of RVing!
There's never a dull moment.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,SmarTire,Bilstein Shocks,Trans temp guage,Lowrace iWAY
RodT82721
Pine Haven, Wyoming
Posted: 06/11/08 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
When plugged in to shore power the inverter should charge the house battery and the Onan also will charge it if running.
2001 Winnebago Minni - 31C
Ford E450 - V10 Triton
Tow - 2005 Jeep Liberty
enblethen
Moses Lake, WA USA
Posted: 06/12/08 07:28am Link  |  Quote  |  Print  |  Notify Moderator
Check under the entry step for another battery or set of batteries. Some used three battery setups. One for the chassis, one for the genset and one for the house batteries. The chassis and house get charged from the chassis system and the genset was isolated and only charged off genset..
RODT82721 is incorrect about charging from the "inverter", your system charges from a "converter".
Bud
Suzuki XL7 pushing Pace Arrow
TreeSeeker
San Diego
Posted: 06/12/08 11:19am Link  |  Quote  |  Print  |  Notify Moderator
There is a lot of variation in charging systems. I have a 79 and it charges the coach battery at a maximum rate of 3 amps via both the converter and the generator. At this charger rate it takes forever to recharge a battery.
If you are parked for a couple of days the converter will recharge it OK. However if you leave it on too long it boils the battery dry and this destroys it.
You can't really charge the battery from the generator since it would take about 16 hours to recharge a battery that was at half capacity. I plug in a 35 amp portable charger to the generator to recharge the coach battery.
Newer RV's have better systems than mine. Yours is not that much newer so you may have a similar system to mine.
You can find a lot of good battery info here:
http://www.phrannie.org/battery.html
