dmzempr
ohio
I noticed a few spots on my new Jayco 29A that needs some touch up caulk. I know about the 100% silicone caulk for home/bath use that is pretty good but what about the industrial stuff the mfg use to caulk at the factory? I'm trying to match what they use.
thx
Dave
2004 Yukon XL 5.3, 3.73, Prodigy, Equalizer 1k/10k
2007 Jayco 29A
5 campers + dog
CaLBaR
Ontario, Canada
Stay away from the silicone. I used it and it peeled after a few months. I then had to clean it all off and use simple green to get rid of the residue. I used Geocel Pro-flex and it has worked great.
2007 Rockwood 8298 SS
2006 GMC Sierra Crew Cab 5.3 V8 3.42
Draw-tite Max-E-Loader Hitch
HP Dual Cam Sway Control
Prodigy Brake Controller
donn0128
Pronounced Ore-gun
Where are these "spots"? IF they are on the roof then use only the Dicor lap seal. If other places then use anything except silicon and you should be good to go.
Donn
dmzempr
ohio
thanks for the tips. I found a few around the door and then the opening for the pass through door which is parallel to the ground. I'll be looking for the horizontals first and then verticals that need touched up.
VernM
Marion County, AR
Then, there are always the caulks the owners manual specifically calls out for use on that brand. Different for windows, roof seams, etc. But, hey!!!!!!!
VernM
GMC Conversion van/Wells Cargo MiniWagon trailer
Sent via HughesNet/SatMex5 Internet Portal
morsecodeham
MA
A second vote for Pro-Flex.
2005 Jayco Jay Feather Sport 186
2005 Ford F-150 XLT Long bed 4.6 V8 3.55 axle
Reese WD & HP Dual Cam Anti-sway
Charlie D.
Gonzales, La.
VernM wrote: Then, there are always the caulks the owners manual specifically calls out for use on that brand. Different for windows, roof seams, etc. But, hey!!!!!!!
I have read 3 different owners manuals and none state what to use.
Enjoying Your Freedom?
Thank A Veteran
2007 Holiday Rambler 32SKT
2006 Chev LT D/A CC
Bubby's RV
CA
Charlie D. wrote: VernM wrote: Then, there are always the caulks the owners manual specifically calls out for use on that brand. Different for windows, roof seams, etc. But, hey!!!!!!!
Winnebago has lists for theirs. Some places are silicone, some are polyurethane and some are something else.
John, Winnebago Minnie 24V
Charlie Q
Brusly, Louisiana
Dicor makes a sealant that is designed for doing this. They make a self leveling and also one that says where you put it. Check Camping World. That's where I bought mine.
'03 Chevy CC/SB,D/A,4X4, Airlift Bags, Bilsteins, Reese slider, Hypertech programmer.
'06 Mobile Scout 31 BWFS
Yamaha 3000ISEB
