silvercrew
Brooks Alberta
I installed mine the same place as on a motorhome. I have a closet right in the back middle of my trailer so that is where I went out. I then ran inside by my shower lines up to the front and went out were the wires for my converter go outside. When I got to the front I insatlled a l braket and installed a splice in it. There is a short cable from there to the truck. The truck is wired the same way but with a weather cover over where the wire is on the back of the truck. I did it this way so if I forget to unplug the camera I only have to replace a little cable and not the whole lenght in the truck or trailer.
2004 Expedition EB 5.4l hd tow pack
2005 Triple E Topaz LE T274XL
Prodigy brake control
Equal-i-zer hitch
Cipa mirror extensions
Proforce gen set
Colman LXE grill
Fordlover
Spring, Texas
youth4him wrote:
I went UNDER the TT all the way to the back. I used a surface mount screw in pipe mount (it has for holes for screws, and you screw in a 1" pipe into it). I went up over my spare tire, so I basically have a 90 degree "gun". The wires run inside the pvc and are siliconed in so it's water proof. I added a switch to my battery box, so when we hook up, I just turn the power on for the camera, and I'm good to go.
I'd love a picture of this, sounds like a great way to do it.
02' Ford Explorer 4.6 V8 4x4, prodigy and equalizer
07' Crossroads Sunset Trail ST19CK
03' Ford Focus SVT my daily driver
04' Volvo S40 wife's daily driver
youth4him
Belgrade, MT
Here are the pics, finally got out there to take them. It's not the prettiest thing in the world (looks like I mounted a paint ball cannon to the back of my TT) but it works well, and I can easily adjust it side to side if needed.
Battery box switch (radio shack)
KD
Trip of a Lifetime Blog - 10372 Miles, 88 Days, 4 Humans, 1 Mini Daschund...FUN!
Wildwood LE 23BH
2003 Chevy Suburban 4x4 Z71 5.3L 3.73
Rumtan
Alberta
That looks really good....ingenious idea using the PVC like that. One question i have is, does it shake when travelling?
2002 Palomino 22'
2002 Chev Silverado V8
Fish-O-holic
mstoetz1
Edmonton, AB
If I was going to install a rear view camera, in my opinion, you should get one that has enough of a wide angle that you can see your rear bumper, or get a really good view of the rear of the trailer so you don't have to guess clearances when you're backing up. I've been investigating cameras for about a year, and find very few have an adequate field of view (ie: 110 degrees or more)
Some have 170 degree FOV which provide an excellent view behind the RV.
This was one I liked if I placed it in the top of the rear window (inside the trailer).
PC228
Fordlover
Spring, Texas
I like these options so far. Question for youth4him, do you store your slinky in the bumper? and if so did the screws in the bumper effect anything? I think I know what direction I'm going to go.
skipm
Saint Helena Island, SC USA
I opted for a portable unit that has magnetic mounts for the camera and the monitor is hand held. I am usually traveling alone so this is a good combination for me because I can place the camera on the back of my TV to hook up or move it to the back of the TT to back into a campsite or whatever need I may have. I bought the unit off E-Bay, here is a link for the set up I have: http://cgi.ebay.com/ebaymotors/Parts-Accessories___Swift-Hitch-Portable-Wireless-Camera-Snow-Plow-Police_W0QQitemZ300233065322QQddnZPartsQ20Q26Q20AccessoriesQQddiZ2811QQcmdZViewItem?hash=item300233065322&
skipm
youth4him
Belgrade, MT
Fordlover wrote: I like these options so far. Question for youth4him, do you store your slinky in the bumper? and if so did the screws in the bumper effect anything? I think I know what direction I'm going to go.
Yep, I used relatively short screws so as not to protrude into the bumper too far and create an issue. There's almost no weight or force on the thing, so I didn't need much.
hotpepperkid
Chino Hills CA
MMMMMM paint ball cannon. I would like to have a 20MM cannon on the back of mine to take care of the tail gaters.
hpk
2000 Ford F-350 SRW 4X4 PSD Jayco Super Lite 29.5RKS 5th wheel 50 gal X-ferflow in the bed tank. Banks big exhaust and Stinger kit.
