Fire44
Smyrna, Delaware
HemiSpiritofAmerica wrote: So I am assuming the guy I saw at a KOA earlier this year shouldn't be towing a Fleetwood Terry Triple Slide 29.5' Fifth Wheel with a Dodge Ram 1500 Mega Cab Hemi?
We tow a 33' (true overall length) 2006 Keystone Outback that has a listed weight of 8800 lbs with a 2006 Dodge Ram 2500 CTD Quad Cab Short Bed with no problems at all. Just try to find as light a fifth wheel as you can that suits you and your family and you'll be fine. I've seen guys towing heavy triple slide 5th wheels with 250 / 2500 Diesel's. Not sure it's the safest thing to do and not sure what modifications they have made to beef up suspension on the tow vehicle but have seen many, many people doing it.
I pull this trailer with a Chevy 2500HD Crew Cab 4x4 Duramax and have not had any problems. I am inside the limits of my truck, even with the 60 gallon aux tank full.
Gary
Gary
Delaware
2006 Chevrolet Silverado 2500HD Crew Cab Duramax
2006 Outback 30FRKS
donawilcox
Taylor TX
Like some said do not go on length alone. I tow a 36' with my 2500 Chevey durmax. I will say I did not come to this forum first and when on what dealer said that I would not have a problem and I do not. I have not checked my pin weight but it does not even push the truck down that far. I had a pallet of grass last month that sqatted the back end down more than my fiver.
Don Wilcox
Taylor TX
2006 Duramax 4X4
2007 295 Cherokey by Forest River
THE BIGPUNN
west michigan
the MI motor vehicle code is so thick the trooper probably wouldnt know where to begin to look that one up! as long as its legal and auto insurance is paid up tow a tank if you like.
07 Chevy 2500HD D-Max!
05 Forest River Wildcat 31 QBH
Tarantula
Saint John, IN
If you pay attention to the "weight police', you'll end up with a 10' pop-up with your truck. Get the RV that suits YOU. We pull a 36' Montana with our '05 Dodge 2500 3/4 ton CTD. And it isn't overloaded.
Our Unit: '05 Dodge 2500 SLT Bighorn Quadcab 4X2. Cummins, Auto, 3.73. Reese 15k 5th wheel. '06 Montana 3000RK.
Saftman
Lafayette, La.
I have the same truck as you do pulling the rig in my sig.
Steering axle--4600#
Drive axle-----5680#
Trailer axles--10280#
Total----------20560#
About 300# over but not enough to worry about. Truck does just fine.
'06 F250 SC, FX4
'06 Cedar Creek 36 RLTS
Me, The Wife & 1 Big Dog
AntiqFreq
Sunny South Florida USA
Our fiver is 30'11" and weighs about 9500 lbs fully loaded.
We tow with an 03' Ford F250, 7.3L, crew cab, SB.
We do just fine with ours.
And YES, we are a few pounds over our cargo capacity, but we keep nothing
in the bed or our truck except 2 extra cans of diesel!
Inside the truck is just me, hubby and our 10 lbs dog.
All the rest is in the back of the trailer.
We try to keep the pin weight down as much as we can.
Our fiver has 2 slides!
Jo
291 RLS Cougar
donn0128
Pronounced Ore-gun
Tarantula wrote:  If you pay attention to the "weight police', you'll end up with a 10' pop-up with your truck. Get the RV that suits YOU. We pull a 36' Montana with our '05 Dodge 2500 3/4 ton CTD. And it isn't overloaded.
More smoke and mirrors in an attempt to say he is not overloaded. No one has ever said that except the people who are actually overloaded and won't admit it! What is your scaled weights?
I do believe that your truck is listed at 20,000 GCWR and 9000 GVWR, so in reality you are overloading the truck by 1280 pounds and the GCWR by over 500 pounds. What are your tires rated for?
edited 06/13/08 08:30am by donn0128 *
Donn
Saftman
Lafayette, La.
The truck is listed at 10,000# and is registered for 11,500# in Louisiana.
kennethwooster
Perryton Tx USA
I'm pulling with a F350 SRW, which had the same weight ratings as your rig. You can't go by the length, as some trailers are made of different materials that are lighter. I have a friend with a 36 ft. Mobile suites, that is very heavy. I have a 38 ft. Quantum that is just perfect for my truck. You must look at the weight of the trailer, and then realize that some of the weight are a guess by the manufacture. I've been across the scales, and I'm right on target, with maybe 500lb. to spare. I carry an extra 91 gallons of diesel in the truck bed, so my rear axle weight may be a little heavy for the first 200 miles of travel. Just be careful and compare the weights of different trailers. We were looking at Hitchhiker, which I love, but it is much heavier. Also the dealer was sort of a jerk, so stayed with the current dealer.
kenneth wooster- farmer
wife Diana-adult probation officer
365BSQS Quad slide 2007 Quantum
Ford F350 2005 model, 4X4 FX, King Ranch
18K SuperGlide Hitch
Saftman
Lafayette, La.
Tires are BFG 285/65/20. 3860# each.
