RV.Net Open Roads Forum: Travel Trailers: shock from screen door and awning arms
 > shock from screen door and awning arms
mmpage
Warren PA
Posted: 06/12/08 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 1985 Terry travel trailer. Packing it this evening my 5 yr old told us the door was giving him a shock.
If you touch unpainted surfaces such as the door and awning arms while standing bare feet on the ground you get a tingle.
What is this from?
Is it dangerous?
Should I not use it this weekend?
please help
gstanton
Oakland, MD and Tierra Verde, FL
Posted: 06/12/08 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a wire is shorting out to the frame of the trailer. 12 volts "usually" does not shock. Assuming this shock is 110 volts - unplug your electric connection and it should stop shocking. At least this way you'll know where it's coming from. If you unplug your electric connection and still get shocked, then there is something going on (in the ground) where you are parked, and not your TT.
If it is your TT, then it would be dangerous to use it until you find the problem. For example you could stand in a puddle and touch the trailer and get electrocuted.
Dusty & Lindsay
Sadie the "Lassie" type collie
Oakland Maryland and Tierra Verde, FL
Our 3rd TT is an '02 26' Nomad Scout
Ford F150
mmpage
Warren PA
Posted: 06/12/08 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
When It is unplugged it doesn't shock
Coyote2cool
Denver, Colorado
Posted: 06/12/08 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
What is this from?
Is it dangerous?
please help
You are missing some information ....
Did you feel this or just your 5 year old
Is the trailer hooked up to shore power
If you have shoes on do you still feel this
2008 Chevrolet Avalanche Z71
2007 KZ Coyote 23 CFK
2008 Total nights camping = 27
Just Remember: When everything is coming your way, you're in the wrong lane
Me (37)... DW .... DD (11) ... DD (9)...Dog (1)
Camping photos & Mod's
b_salgado
Salisbury ,NC,USA
Posted: 06/12/08 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
Check our extension cord. It sounds like you have a missing ground pin.
04 Lariat Supercrew 4x4,5.4,3.73, Edge tuner, flowmaster duals
06 Trail Bay 31BH, nicely optioned
Equal-i-zer
Prodigy
Follow vehicle, 05 KIA Sorento EX for the golden retrievers.
henw
Posted: 06/12/08 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Check your polarity as well.
JJBIRISH
Butler, PA, USA
Posted: 06/12/08 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
I would not use it until I found the problem... without knowing the cause it is difficult to say just how dangerous it might be...
Love my mass produced, entry level, built by Lazy American Workers, Hornet
dbbls
Missouri
Posted: 06/12/08 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
This would be my guess. Wires in the outlet are wired backwards.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
silvercrew
Brooks Alberta
Posted: 06/12/08 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
If it doesn't do it with the 120v unplugged, then that is likely where the problem is and I wouldn't plug into shore power until you get a chance to search out the issue. The trailer you could still use for dry camping and it shouldn't be a issue. If it still does it with the trailer unplugged I would be really careful around the trailer and keep your kids away from it until you find what it is.
2004 Expedition EB 5.4l hd tow pack
2005 Triple E Topaz LE T274XL
Prodigy brake control
Equal-i-zer hitch
Cipa mirror extensions
Proforce gen set
Colman LXE grill
Jamesrpm
Oregon Coast
Posted: 06/12/08 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Could be your outlet you are plugged into or your cord, if it does it on known good outlet, replace / repair cord as you rv grounds from the wire in the cord. Also be very careful small children are at a much higher risk from electrcal shock , lower voltage or amperage will harm them.
___________________________________________
I plan on living forever , so far , so good
