thehoosier
Indy
What is recommended to lubricate the levelers while they are extended ?
ernestfortier
Palmdale, Calif.
Spray silicone. Works great, keeps them wet, doesn't dry out.
Ernie Fortier
99 Bounder 34V
2 honda 2K paralled (for economy)
5.5 Onan onboard
96 Geo Tracker 4x4 Auto. convertable
tallyo
Fort Myers,Florida
My Winnebago has HWH jacks and they say use nothing.....other than wipe them to keep clean if dirty.....
Tallyo
2007 Winnebago Adventurer
W-24, 6 spd Allison
Saturn VUE w/ Brake Buddy Vantage
Drinks-6, Eats-4, Sleeps-2
Semper Fi
Fulltimers
Anywhere, USA
Tallyo is absolutely right if they are hydraulic. They are basically self-lubricating. When the jacks are up they are lubed. If you feel the need to, when you wipe them down put a little automatic transmission fluid on the rag and wipe them clean.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2001 Saturn SC2 (Mr. Toad
Photos
Deen
Vancouver, WA
tallyo wrote: My Winnebago has HWH jacks and they say use nothing.....other than wipe them to keep clean if dirty..... Also have the HWY and they don't require lubing.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
utmtman
Anywhere USA
Well mine dragged so I spayed them with silicone and now they work great and I will do it again the next time they hang up. And yes I tried to wipe them clean, I also used a pry bar and blocks to push them up after that and finally the spray. Much happier now.
Lee & Fran
2005 37 Ft Holiday Rambler Vacationer Gas Hog
While traveling down lifes paths, stop to smell the flowers.
Wherever I happen to park
Power gear w/o zerk fittings Silicon
Power Gear WITH zerk fittings A single pump of white lithium
HWH says "Do not lubricate"
LVJ58
Las Vegas, Nevada
In the 8 years we've had our coach, I've never lubricated or even cleaned the leveler rams. No problems, no leaks, we have the Kwikee 2000 series system.
Jim & Sherry Seward, FMCA #F342207
2000 Residency 3790 V-10 w/tags
2003 Suzuki XL/7 Towd
thehoosier
Indy
thehoosier wrote: What is recommended to lubricate the levelers while they are extended ?
I have the Bigfoot levelers and they mention something about using a dry silicone spray . I don't know that I've ever heard of a dry silicone spray ?
Rich D.
New England
As a rule; nothing, unless they get very dirty and won't retract. Then wipe with transmission fluid which is what is used in the system. Some folks clean the rams with WD40 but if you don't get it all off it will eat the rubber seals. I would not use it at all, JMHO.
Rich D. Wanderlodge LXi 43'
