RV.Net Open Roads Forum: Help, New Yamaha 2400 won't run 13.5 AC
 > Help, New Yamaha 2400 won't run 13.5 AC
Page of 6
ckelly
Lincoln, NE
Posted: 06/12/08 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
Okay, I'm about to do a little panic dance here. I just bought a new Yamaha EF2400is generator from Wise Equipment and tried hooking it up to the '07 Jayco 27BH w/Coleman Mach 3 Plus 13.5 AC unit. When I kick on the AC, nothing else on except the converter w/fully charged batteries, the little Yamaha goes to full throttle the AC unit sorta hums but won't start and finally the overload trips on the generator.
Sooo, now what? Do I have a $1100 generator I can't use??? OMG
The specs for the Mach 3 state 10.9 A for the compressor, and 3.4 A for the blower on High (I was on low, or 2.4 A) for a total wattage of 14.3A x 115V = 1644.5 W
Ideas??? HELLLLLPPP!!
'00 Ford Excursion 7.3PSD, DP Tuner, Isspro gauges, BTM
'07 Jayco 27BH - Delivery taken, 5/15/07
'96 Larson 174SEI 4.3GS Volvo
rjf7g
Virginia
Posted: 06/12/08 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
Have you checked the output of the generator or the draw from the AC with a meter? According to the Yamaha web site, your generator produces:
Maximum AC Output 2400 watts
Rated AC Output 2000 watts
Rated / Maximum AC Current 16.7 / 20 amps @ 120V
Either your AC is drawing more than you expect, your generator is putting out less than you think, or you have something else drawing current.
1992 Fleetwood Tioga Montara Special 27 Class C
2007 Gulfstream Innsbruck 36FRS Park Trailer
closurdo
Michigan
Posted: 06/12/08 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure that your hot water tank element is turned off.
1999 Dodge Ram 2500 QC
1998 Sunnybrook 26cks
Equal-i-zer Hitch
Visit my website
Wayne Dohnal
Banks, OR.
Posted: 06/12/08 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
And that your fridge is on "gas only".
2009 Fleetwood Icon 24A
LinkPro battery monitor
EU2000i generator
BBFD
Outside Rochester, NY
I have found that with my Coleman 13.5 in order to lower the draw I first start just the fan which draws nearly 5 amps and then settles down to around 3 amps. After the fan is running I then start the compressor by turning on the AC. This seems to cut down on the initial shock to the power supply (line current or generator). I used my Kill A Watt meter which is only rated to 15 amps and found that when I started everything at once the meter went into alarm mode and beeped. By starting each item separate it did not overload and alarm so maybe try that.
2008 KZ Spree 255KS, 2005 Ford Expedition E/B, 2 6-volt Interstate U2200's
dclark1946
Richardson,TX,USA
Posted: 06/12/08 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
Certainly check your ac current draw without the AC to see if there are any other significant loads. You should look into the ac/dc clamp on meters that Sears sells to check the current. You may however be too marginal. A soft start kit may help. Worse case, change your AC unit to a Mach 3 PS that draws 4A less current compared to the standard Mach 3. I have been able to start mine (PS version)with a Honda EU2000. Even so the peak current is on the order of 20A when powered from an ac outlet.
Dick
* This post was last edited 06/17/08 03:06pm by dclark1946 *   View edit history
Dick & Karen (converted tent campers)
Richardson,TX
2007 KZ Spree 240RBS
03 Tahoe/04 F250 PSD
ckelly
Lincoln, NE
Posted: 06/12/08 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
Water heater is off, fridge is off, lights are off. Nothing is on. I have not pulled fuse in converter, but I shouldn't have to - should I?
No, I haven't put a current meter on it not do I know if I can get it done in time for that and get whatever fixed/exchanged/etc. anyway...We're leaving for Yellowstone next Friday, June 20th!!
ckelly
Lincoln, NE
Posted: 06/12/08 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
I've read these do have to "break in" a while, is this correct?
I'll get a clamp on ammeter tomorrow and see what's going on. Do I need to tear an extension cord apart and get across the "hot" wire only for those?
Change the AC unit? Is the Mach 1 and upgrade from the Mach 3??
JConatser
Smyrna, Tennessee, USA
Posted: 06/12/08 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
ckelly wrote:
... Do I need to tear an extension cord apart and get across the "hot" wire only for those?..
That's one way to do it... however, you should be able to buy a small adapter made just for that purpose at the same place you buy the clamp-on ammeter.
Ameri-Lite 24RB
1997 Chevy 1500 Ext Cab, 5.7L
Equal-i-zer Hitch
Anyoltime
Strathmore,AB
Posted: 06/12/08 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
You have a locked rotor amperage at start up of over 35 amps.get a soft start kit and the yammy should hang in there long enough to roll it and bring down the amp. to running capacity.Doing a sequential start up as suggested above will help.
Page of 6
