RV.Net Open Roads Forum: Tech Issues: AIR COMPRESSOR FOR TIRES
 > AIR COMPRESSOR FOR TIRES
The Bayfield Bunch
Bayfield Ontario
Posted: 06/13/08 11:36am Link  |  Quote  |  Print  |  Notify Moderator
The Canadian Tire Store here in Canada is advertising an air compressor this week which happens to include a nailer/stapler thingy. Tried to include a picture but didn't work. Am wondering if this would be acceptable for keeping the tires on our Class A motorhome tuned up if necessary plus blowing out waterlines for winterizing. I'm not good at understanding tech stuff so I've included the unit's specs below. On sale for $199.00..... Thanks.
Includes two-in-one brad nailer/stapler
No tank required - air is stored in tubular frame for a more compact, lightweight unit
Protective coating reduces temperature and noise, and protects against rust and damage
High output: 5.1 CFM @ 40 PSI; 4.1 CFM @ 90 PSI
1-gallon, 2 peak HP motor
Pump does not require oil, which means reduced maintenance
30% lighter than traditional compressors with the same high output
125 max PSI
Exclusive to Canadian Tire
Kelly & Al
2003 Damon Challenger, model 329 Chevy Workhorse 8.1 & Allison transmission. Towing '03 Hyundai Santa Fe 4 cyl 5 speed.
3 lovable doggy guys. Max, Checkers,& Cora..aka, Buddy Bear, Swamper, & Motormouse
http://TheBayfieldBunch.com
tom_kat
way upstate new york/lake george area
Posted: 06/13/08 11:51am Link  |  Quote  |  Print  |  Notify Moderator
if the pressure goes high enought it would work for tires you really need a larger tank with more air volume to blow out the water lines realy well.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
amxpress
Clayton, NC
I have a similar size air compressor with a 1 Gallon tank; 125 psi.
It is great for inflating the 15" tires on my fiver, but it doesn't have enough capacity to inflate a Class "A" tire. My neighbor has a HR Class "A" and we tried to air up his tires. It didn't work.
It has pressure, but not enough volume.
Save your money, unless you want to do some power nailing.
* This post was edited 06/13/08 06:32pm by amxpress *
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2008 Palamino Sabre 31RKTS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Travel in peace...leave the M-I-L at home.
Fish On I'll Get the Net
Dryden, Ontario, Canada
Posted: 06/13/08 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
I purchased a smaller one last year called Job Mat. It’s a 3 gallon and 100 psi max. I use it for the car, truck, and camper and its very light weight. It was on sale at Canadian Tire about $50.
KeninAZ
SE AZ
Posted: 06/13/08 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
An oilless compressor usually means it has a limited # oof ours it will run without rebuilding it.
I have had them before.
2oldman
WA
Posted: 06/13/08 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
I'd be leery of that statement about no tank. You'll appreciate having a compressor with a 4 gallon tank.
The Bayfield Bunch
Bayfield Ontario
Posted: 06/13/08 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the feedback on the compressor. Seems to be some legitimate doubt about it's capabilities so I have decided to return it to the store. Luckily I hadn't even opened the box. Any suggestions for a good reliable type of air compressor to carry on board?
Bobbo
Memphis, TN
Posted: 06/14/08 08:08am Link  |  Quote  |  Print  |  Notify Moderator
MV 50 or one of its clones. I have the Harbor Freight clone because it has a metal body instead of plastic.
Bobbo, Linda and the furry kid (German Shepherd)
'07 Winnebago Outlook 31C on a Ford E450 Super Duty Chassis
NRA Life Member
Near N35 12 17 W89 50 57
2oldman
WA
Posted: 06/14/08 09:13am Link  |  Quote  |  Print  |  Notify Moderator
Air compressor
More air compressor
Tsunami compressor
12v compressor
chuck4788
West of the Middle
Posted: 06/14/08 10:46am Link  |  Quote  |  Print  |  Notify Moderator
My experience from inflating tires is that the air compressor needs to be rated at least 25psi higher than the desired pressure in your tires. Actually the criteria is cutin pressure for the compressor, which is about 20-305 psi less than the max rating. The air system on my MH runs at 125psi but the compressor cutin is 90 and it won't air up my 120psi tires. I bought a Porter-Cable 150psi rated air compressor with a 6 gallon pancake tank and it works great. You also need at least several CFM at 90psi and/or a tank or you will spend 15 minutes holding an air chuck on a tire to add a few psi, this eliminates most of the 12 volt compressors. My 2.5 ProSine will run my air compressor.
Chuck
02 Beaver
505hp C12 Cat
Trailblazer toad
