RV.Net Open Roads Forum: General RVing Issues: dometic refrigerator
 > dometic refrigerator
houhjc
at the pump, tx
Posted: 06/13/08 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
how do i adjust the temperature on my fridge? it seems to stay the same temp on electric or gas, it doesnt matter. I have a temperature gauge inside the fridge, and the needle is on the line between refrig ok, and warm. the freezer keeps things froze, but i would like to cool the fridge more. my book covers rm 2652 and rm 2852. not sure which one i have right of the top of my head.
2007 Ram 3500 6.7 DRW 4X4 6speed manual
2003 362bbs bunk house
my3wags
Corona, CA
Posted: 06/13/08 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
Inside the fridge are some aluminum fins. On one of the fins is a white plastic thermister with a wire on it. Take the thermister and slide it to the top of the fins. this is how you adjust the temp "up for cooler, and down for warmer" that should help
Good luck
Big E and family of three
2002 F250 SUPERDUTY CREW CAB 4X4 7.3 PSD
Most of the goodies !!
2004 KEYSTONE SPRINTER 297 FWBHS
Some of the goodies
Hunting in the Imperial Valley !!!
bucky
Eastern Shore of MD
Posted: 06/14/08 04:36am Link  |  Quote  |  Print  |  Notify Moderator
Replacement circuit boards from Dinosaur have a temp knob built in that the OEM's don't. RVMobile sells them for around $100. I see your unit is 5 years old, it's probably about time anyway if it's a Dometic LOL.
99 F250 PSD CC LB 3.73 4X4 7360 lbs, and it can sink in the mud FAST, 2004 Coachmen Catalina TT 297RKS 8200 lbs on the road.
racefan1965
Redding, Ca.
Posted: 06/14/08 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
HMMM...took 24 years for mine to need replacement. Could be that they knew how to make them back then too though.
Rick
Rick, Shirley, Lacy, Misty and 2 dogs(Shasta & Baylee)
1999 Dodge 2500 Quad Cab 4X4
1984 Alpenlite24 5er
1988 Coleman pup
2006 Champion C46540 RV plug ready genset
Wherever I happen to park
Posted: 06/14/08 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
Same temp on Gas or Electric = working as designed
There are 3 ways to adjust 'fridge temp.. Depending on the model
Some types have a knob you turn, I gather yours does not or you'd not be asking
Mine has a button.. you push it and a series of LED's light up.. Colder or warmer depending on the button pushed or how many times.. Again, I assume you don't have this or you'd not ask
All have a plastic clip. usually white, attached to the fins on the back of the area where you put your food... This clip can be slid up or down on the fin somewhat
The higher the clip is on the fin.. The colder the fridge IIRC
racefan1965
Redding, Ca.
Posted: 06/15/08 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
Not "ALL" have the plastic clip on the fins. My older RM763 does not have this clip. It has a seperate temperature control knob next to the on/off knob on the front of the unit. Let's make sure the info we provide is accurate after all.
Rick
GrammaAnn
Benbrook, Texas
Posted: 06/15/08 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
Well, I learned something new today. I never knew what that clip thingee was, never really gave it a thought.
The refrigerator has always just stayed cold enough. I guess it has been adjusted correctly all along.
Gramma Ann
The Texas Gypsy
New to us - 1988 Shasta 32ft with full handicap accessibility. Move over world Gramma and Grampa are on the road!!
One OLD Hubby, Logan the dog, and Baby the cat ( both left over from the granddaughter !!)
houhjc
at the pump, tx
Posted: 06/18/08 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
i slid my white clippy thingee down on the aluminum fin, as per holiday world service man expressed, and it got colder. perfect.
