RV.Net Open Roads Forum: Travel Trailers: My Black Tank Clog Strategy
 > My Black Tank Clog Strategy
Hornet28BHDS
Parker, PA
Posted: 06/14/08 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
A Flush King may solve your problem.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
revump
Las Vegas
Posted: 06/14/08 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
A short trip and a bag of ice will break up anything that is in the tank. I am not sure that it would reach anything in the pipes. I like that back flush with a hose too.
Bob
Hoppers4
Port Orchard, WA
Posted: 06/14/08 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
Had a gray tank clog once that I solved using the hose connection on my drain cap. I changed out my drain cap early on to verify there was nothing that was going to be blasting out when I took it off. Some folks think it's cool to pull a valve on ya and then close it filling up the drain pipe between valve and drain cap. Hose connection on drain cap prevents much spillage.
These caps can be had at a lot of different places like Wally's, Freddy's or any RV place.
08 Winnebago Sightseer 29R
ManInACan
Long Island
Posted: 06/15/08 10:24am Link  |  Quote  |  Print  |  Notify Moderator
get a flush king.
2005 Gulfstream Conquest 30 BHS.
2003 Dodge 2500 CTD HO 48RE
Me,Wifey,J.R.,Fido
Hgarnerno1
Tyler, Texas USA
Posted: 06/15/08 11:33am Link  |  Quote  |  Print  |  Notify Moderator
I know this sounds kinda gross, but sometimes it is necessary. I once had a clogged pipe due to using just regular toilet paper. I had to get a section of broomstick and unclogged it from the inside. It did work though. Good Luck..
Howard, USN Ret
2000 Ford Excursion,V10, Limited
2003 Terry 27H. Super Slide
nevadanick
Elko, Nevada
Posted: 06/15/08 11:41am Link  |  Quote  |  Print  |  Notify Moderator
In my manual for my KZ it says to use Drano or Liquid Plumber, to help clean the tank, i would imagine that it would help break up the clog.
Rumtan
Alberta
Posted: 06/15/08 11:50am Link  |  Quote  |  Print  |  Notify Moderator
You may just want to poke an old hose up from the outside drain.....its flexible and yet firm enough to unclog your tank. It will go around bends well and wont harm anything.....just stand back when it hits the clog.
2002 Palomino 22'
2002 Chev Silverado V8
Fish-O-holic
Catfishman
North Texas
Posted: 06/15/08 11:53pm Link  |  Quote  |  Print  |  Notify Moderator
When I approached the DW about her using your suggested technique, she recoiled and informed me that I would be contacted by an attorney in the morning! Seriously, I'm prepared to use this method if all else fails. I'm just hoping for the Rid-Ex to work.
2003 GMC Sierra 1500
5.3L - 3.73 Ratio
2002 Coachmen 249QB
If you can't fix it with a hammer, you've got an electrical problem!
Perrysburg Dodgeboy
Perrysburg, Ohio USA
Posted: 06/16/08 08:25am Link  |  Quote  |  Print  |  Notify Moderator
If you get to the point were you need to open the valve then shove a hose into it may I suggest that you try the Flush King or similar product. I’m sure it would do a much better job then a garden hose would.
Remember the clog will be right at the valve blacking the flow so the high pressure stream should break it up. You could also get a plumbers snake and run it down thru your toilet and see if you can break it up that way.
I would try every other method before I opened my Valve and shoved a hose in it.
Just an idea, the next time you go out camping fill your black tank up about ¼ of the way and add your chemicals before you start using the toilet. By doing this it will help keep the mound from forming in the first place (things will tend to float and not stay in one place).
Don
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
pics
19Sandie54
AZ
Posted: 06/16/08 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Don
We were told to always keep water and chemicals in the tank when not in use along with water in the toilet. After emptying our tank and cleaning it, we will always add water to the tank with chemicals and leave it in there. It is never completely empty.
JJ & Sandie
Li'l Jack, Pickles & Bunny the chihuahuas...Chewy, poodle 6/15/95-7/4/08 We will always love you Chooch.
2003 Chevy 2500HD,LT,CC,SB,4x4,Duramax/Allison
2007 Starcraft Homestead 262RKS
