RV.Net Open Roads Forum: Odometer readings are faded & hard to read
 > Odometer readings are faded & hard to read
The Bayfield Bunch
Bayfield Ontario
Posted: 06/15/08 09:47am Link  |  Quote  |  Print  |  Notify Moderator
We have a 2003 Damon Challenger motorhome. It's been sitting for about a month & when I started it up this morning I noticed that the computerized odometer was difficult to read. Numbers & letters were faded & patchy, much like something coming out of a printer with near empty print cartridges. I let the engine run for about 10 minutes but the problem didn't seem to resolve itself. Reminded me of a calculator with very weak batteries. Wondered if anyone else has had this problem......Thanks.
Kelly & Al
2003 Damon Challenger, model 329 Chevy Workhorse 8.1 & Allison transmission. Towing '03 Hyundai Santa Fe 4 cyl 5 speed.
3 lovable doggy guys. Max, Checkers,& Cora..aka, Buddy Bear, Swamper, & Motormouse
http://TheBayfieldBunch.com
ArchHoagland
Clovis, CA, USA
Posted: 06/15/08 11:00am Link  |  Quote  |  Print  |  Notify Moderator
My 2004 Workhorse with the 8.1 has had the instrument cluster replaced twice for bad display. Very common problem on the Workhorse gas chassis.
Your sig says you have a 329 Chevy workhorse. Never heard of that. The 8.1 is about 498 cubic inches.
2004 Monaco
La Palma 36DBD
Two Slides
2 Potties
Workhorse 22 chassis
8.1 gas engine & Allison transmission
6.9 MPG based on a 6,000 mile trip around the U.S.
US Gear Toad Brakes
slippity
Utah
Posted: 06/15/08 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same issue but I can't remember if the instument cluster was replaced under a Workhorse recall, you may want to check. Also, it took 1 week for Guaranty, where it was replaced at, to get the part, so make plans accordingly.
USAF Veteran
1999 GMC Sierra 2500 6.0 V8 Extended Cab 4x4 4.10
2002 Forest River Salem Lite 25' w/slide
The Bayfield Bunch
Bayfield Ontario
Posted: 06/15/08 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
I think your right about the faulty instrument cluster problem. I checked back through my re-registration vehicle history papers & found out the previous owner had replaced that odometer in July of 05. My next step will be to find a Damon dealer in the area & go from there. Thanks....
Yes, we have an 8.1 Workhorse. The coach model is 329 & I've ammended our signature & made it a bit clearer.... Thanks.
Wherever I happen to park
Posted: 06/15/08 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
There was a TSB issues on some of the workhorse dash displays
However read your manual under adjusting display contrast 1st
bsinmich
Holland, MI
Posted: 06/15/08 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
There has been a problem with the Actia display on WH chassis. If you got to IRV@,COM you will find many comments on the WH forum. I am on my third display on mine. Here in the States WH has to replace the display because of laws regarding accurate odometer readings. I must say the current one is much better than the previous one. They will have to get your current mileage and then order the new one for replacement with the correct reading already set. The 8.1 motor is 496 cubic inches.
2003 Newmar Mountain Aire, Workhorse W22, & 2002 PT Cruiser w/Remco lube pump, Falcon 5250, & US Gear Unified Tow Brake
Berjmobile
El Cajon, CA
Posted: 06/17/08 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
I have a similiar problem. The odometer simply quit - no numbers, just dashes. I inquired on another forum and I was told that because I reported that the cluster instrumentation is working, my problem is not with the cluster itself but in the odometer. It appears that Fleetwood will have to some recalibration. Haven't got to it yet. I dread having the dash disassembled! Jim.
JAG
1993 Pace Arrow Diesel
2004 Saturn VUE V6 AT
El Cajon, CA
Williamh
Southeastern Virginia
Posted: 06/17/08 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem you are having. I called the workhorse customer service number in the manual and the gentleman that I talked to told me that there is an open recal on the actia odometer. That gentleman gave me the name of a workhorse service center which was only about 40 miles from my home. I did have to take the MH to them. They did their work and ordered the new odometer. It sure is much better. I can see the numbers now. It was all done under the recall. I took about a week from the time I took it to them until I got it back. Give Workhorse a call and if you don't have the number, PM me and I will get the number for you. Its in a workhorse book a friend gave to me.
William
wdirkin
Gobles, MI
Posted: 06/25/08 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
My odometer just quit when I go my RV out of storage. No numbers, just dashes. I discovered that my predecessor owner had replaced the thing some years before! The old one was in a box of parts. It is a "PEMCO" plug in module. It has a battery welded into it! I believe that when the battery wears out - no odometer. I tried finding a replacement part, but can't find anything. Any ideas on how to fix that?
'93 Fleetwood Coronado
Gobles Michigan
