As I understand it, hydraulic slides drift when in transit and need to be locked down. I full timed for three years with a Jayco with electric slides and never had the need to lock them in.
Road Phantom wrote: As I understand it, hydraulic slides drift when in transit and need to be locked down. I full timed for three years with a Jayco with electric slides and never had the need to lock them in.
Never heard of that. My hydraulic slide works on a rack & pinion gear system that need the pump motor to be activated to move the slide; it never budges on it's own. There is no locking mechanism for it since it's not required.
Eric
2009 Holiday Rambler Admiral 33SFS
Good Sam's - FQCC/Camping Quebec My Photos
I believe more problems on this forum using hydraulic slides than electric but maybe there are more hydraulic slides than electric now. I haven't had any problems with our electric power gears slide and don't think I would like the other because electric doesn't seem to leak much. Yes hydraulic slides can work out driving down the road. chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
