RV.Net Open Roads Forum: Tow Vehicles: 2006 Ford F 150 4x4
Search only in Tow Vehicles
 > 2006 Ford F 150 4x4
L_team
Ohio
Posted: 06/15/08 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
Hey guy I have found an 2006 Ford F150 4X4 Super Crew Cap. It has the 5.4L with factor tow package. Does anyone have an pros or cons on this TV. We do not have a TT yet, but really looking, think more like this winter to due work. Not real sure of gear ratio but will find out in the morning and will post tomorrow night. I have 4 kids ages are from 2 to 9 so we are looking at the Quad Bunks House TT. This TV is sitting on a local lot and they have it listed for 16000.00 and the dealer is very reasonable when comes to down to it. Thanks in advance for the advise.
Paul
2001 Dodge Dakota Quad Cab 4x4
4.7 with 4:10 rear
Prodigy
mikehart92
Oklahoma
Posted: 06/15/08 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
If I was just starting out looking for a tow vehicle, there is no way I would start in the half ton area. It will seriously limit your tt choices.
Mike
Boilermakers Local 592
2005 Chevy 2500HD.............6.6 D/A, 4x4, Crew Cab
Terryallan
NC
Posted: 06/15/08 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
Can't help much without the gearing. Could be from 7000lbs to 9000lbs. 150s make great TVs, as long as you stay in the recommended weight limits. Good for most normal TTs.
The supercrew has lots of room front, and back. Also has a long enough WB for good sized TTs. As long as many 2500, and 250s.
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/15/08 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
As long as you dont change your mind and decide you want a fifth wheeler or a truck camper, the F150 truck will be fine for pulling travel trailers. The motor may be underpowered for the real big trailers but should handle most of the medium ones. Definitely find out what the gear ratio is. In a 4x4, changing the gears cost $1500 and could kill the 'good deal' you get on the truck.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
Steve_in_29
29 Palms (SEMPER FI), CA 92277
Posted: 06/15/08 11:36pm Link  |  Quote  |  Print  |  Notify Moderator
A guy at work bought a 5.4L F150 to tow his (28' IIRC) trailer. He believed the salesman's pitch that the truck would handle up to a 9Klb trailer. It would but not very fast and not very often. After a couple of trips he upgraded to a Dodge 2500 diesel and is happier even though he had to eat it on the trade.
If you are looking at a small/light trailer, don't plan on towing any real distance or going over mountains the F150 would work ok. But with 4 kids (that will only get bigger) you are probably looking at a pretty good sized trailer and so you should get a truck that will handle one. Trucks are cheap now so getting what you need isn't as big a hit as it used to be a year ago. Ford is offering employee pricing again as well.
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
LimogesMan
Ontario, Canada
Posted: 06/16/08 06:18am Link  |  Quote  |  Print  |  Notify Moderator
Great half ton truck. Chances are it's equipped with a 3.73 limited slip axle.
When shopping for that TV, look for a GVWR of 8000lbs or less and you'll be ok.
Happy shopping.
2002 Ford F150 SuperCrew 4X4 FX4 Lariat, 5.4L Triton V8, Precision 4.10LS
2004 Keystone Springdale 249BH 26' Fifth wheel (5800# empty)
Husky 16K dual pivot glider. TomTom One 3rd edition.
18 mpg empty, 11 mpg towing.
rdturn
Indepenence, MO. USA
Posted: 06/16/08 10:03am Link  |  Quote  |  Print  |  Notify Moderator
My F150 is a great truck. I tow 6800 loaded and have 0 issues. It depends on whether you will find a TT to math the trucks capabilities. If your looking for a large trailer then you might want to consider a 3/4 ton truck. If not the Ford should do just fine. Good luck!
-Roger
2007 Forest River Salem 28FBSS
2006 F-150 Ford 4x4 S/B
More picutes
windellmc
Indianapolis
Posted: 06/16/08 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
I hear 4 kids and quad bunkhouse and immediately think Excursion or 3/4 ton Suburban. A 3/4-1 ton Dodge Megacab might also be good. Any 1/2 ton truck is pretty marginal on GVW with an 8k trailer before you try to put 6 people in the cab plus bikes, firewood, etc. in the back.
smkettner
Posted: 06/16/08 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
Look at some quad bunk trailers and see if the GVWR of the trailer is in your tow rating.
I hear lots about great prices on the larger trucks in good used condition and so I suggest a 350/3500 srw. You will probably need more than the F150 has to give.
L_team
Ohio
Posted: 06/16/08 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the advise. I called about 10:00 am and they made a deal with someone when the doors open at 9:00. I guess that this was not the one for me. Once again thanks.
Paul
