RV.Net Open Roads Forum: Dinghy Towing: Jeep Wrangler
Search only in Dinghy Towing
 > Jeep Wrangler
Deb and Ed M
SW MI, USA
Posted: 06/17/08 10:11am Link  |  Quote  |  Print  |  Notify Moderator
Once we're camped at our destination, we like to follow those un-named little roads that take you to fabulous spots in our Wrangler - you just haven't gone sightseeing until you do it "topless"....LOL!!
Deb
sigthor
san antonio, texas, usa
Posted: 06/17/08 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
Fun vehicle but the fuel mileage SUCKS!
2001 Allegro Bay DP, Banks Stinger Installed
2007 Wrangler X Unlimited 4WD, Blue Ox Aventa II
Texasjeep44
Posted: 06/17/08 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
And the milage in the MH that is towing it is good?
I assume that most toads get less miles put on them than the tow vehicle itself, depending on how much time you spend on the road.
To answer the question, I like the way my Wrangler tows and it was very simple to set up for it.
bacollins
Lawrenceburg, IN
Posted: 06/17/08 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Both our Cherokee and Wrangler are terrific toads. The problem is deciding which one to use.
'92 Itasca Sunflyer P series Chevy
'99 Wrangler Toad
'99 Cherokee Toad
'00 Yamaha WR 400
'05 KTM 450 EXC
'92 Honda 750 Nighthawk
Hikerdogs
Wisconsin
Posted: 06/18/08 07:17am Link  |  Quote  |  Print  |  Notify Moderator
We get 16 mpg in town and 21 mpg on the highway with our 04 Wrangler automatic. When you compare it to the motor home or my Ford Expedition it seems pretty good.
Hikerdogs
2001 Winnebago Adventurer
N7UMS
Enumclaw, WA, USA
Posted: 06/18/08 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
targaboat wrote:
Are you kidding? It is probably one of the most popular Toad. Just make sure you get the FWD and the neutral disconnect option. Some do not come this way.
No such "Option" on Wranglers. ALL wranglers have a transfer case (NP231 or NP241) with a neutral position which totally disconnects the two driveshafts inside the case. The shafts will still spin but won't be connected to the drive train.
Don't beat your head against a wall trying to find a "disconnect option", they all work this way. Same with the 4wd Libertys as they too had the NP231 T-case.
Ed/N7UMS
31' Fleetwood Flair, Georgetown 378TS on order
'98 Jeep Wrangler Toad
www.nwjeepn.com
The Trail Starts Here!
"I can fix it, and if I can't fix it, I can fix it so nobody can fix it!"
Paul V
Concord, Ca.
Posted: 06/19/08 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
Jeep Wrangler, what more can you ask for in a toad. Seats 4, top on or off, 4x4 go any where you choose and so easy to tow.
2001 GMC Crewcab Duramax 2500HD 4x4
2006 Outfitter Apex 9.5
1997 Jeep Wrangler
Hikerdogs
Wisconsin
Posted: 06/20/08 07:28am Link  |  Quote  |  Print  |  Notify Moderator
"ALL wranglers have a transfer case (NP231 or NP241) with a neutral position which totally disconnects the two driveshafts inside the case. The shafts will still spin but won't be connected to the drive train.
Don't beat your head against a wall trying to find a "disconnect option", they all work this way. Same with the 4wd Libertys as they too had the NP231 T-case. "
All Four Wheel Drive Wranglers have transfer a case. The 2 wheel drive versions don't have them and can only be towed 4 down after disconecting the drive shaft.
N7UMS
Enumclaw, WA, USA
Posted: 06/20/08 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Hikerdogs Wrote:
"All Four Wheel Drive Wranglers have transfer a case. The 2 wheel drive versions don't have them and can only be towed 4 down after disconecting the drive shaft."
Let me make this perfectly clear for those that don't know anything about Jeeps. THERE IS NO SUCH THING AS A 2WD WRANGLER! ALL wranglers YJ/TJ/LJ are 4wd with either the NP231 or NP241(Rubicon models) T-cases. These T-cases have a neutral position and can all be towed 4-down.
My web site is: www.nwjeepn.com if you think I don't know what I am talking about.
Hikerdogs
Wisconsin
Posted: 06/20/08 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
Here's a link to information about 2 wheel drive Jeep Wranglers:
http://www.jeep.com/en/2008/wrangler/capability/drive_systems/
A quote from this page (on the Jeep site) states: 4x4 capability has been the Jeep vehicle's trademark for over 6 decades, But Jeep Wrangler Unlimiteds come with 4x2 rear wheel drive capability offering another side of Jeep brand performance.
* This post was edited 06/20/08 01:22pm by Hikerdogs *
 > Jeep Wrangler
