RV.Net Open Roads Forum: Chip Seal Project Hwy 50 Ridgway, CO ruins exterior
 > Chip Seal Project Hwy 50 Ridgway, CO ruins exterior
jkdavis22
Colorado
Posted: 06/15/08 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
Not far down the hwy., heading to Canon City, CO the engine belt broke on our cummins engine which has less than 3500 miles. If you could see the rear of our motorhome, covered in tar and chip seal debris, you would blame the belt breakage on the chip seal project. This is maddening. Stranded 5 days in Grand Junction Co for repair was a real experience, belt threw itself into the air conditioning compressor and that as well needed replacement. Anyone have ideas on the best way to remove this from my clear coat paint exterior?
grm77979
South Texas
Posted: 06/15/08 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
You may want to try WD40. I would try it on a small area to make sure it wont hurt your finish, good luck.
Glen
1997, 40' Mountain Aire DP, one slide
325 Cummins, 6 speed Allison
Toad - Jeep Wrangler
downtheroad
Puget Sound
Posted: 06/15/08 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Exact same thing happened to us (except for the break down).
I ordered this product and it worked very well...was safe for the finish and easy to use.
After I ordered it on line I found that my local auto parts store stocked it so check there.
TARMINATOR
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Pic
Reese Dual Cam HP
Sully2
Cincinnati
Posted: 06/15/08 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds to me like a good reason to travel to and fro on the INTERSTATE highways!!!
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
skipnchar
Topeka Kansas USA
Posted: 06/15/08 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Most any good "bug and tar" remover should work just fine. I'd check with your manufacturer if you believe the belt was due to the road you were driving on because chip seal is used in every state and it SHOULD be able to be driven on most any standard type of highway without damaging it. Good luck / Skip
joppa
Massachusetts
Posted: 06/15/08 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
Good news is the tar comes of easier than the love bugs
The World is a book, and those who do not travel read only a page. ~St. Augustine
2007 Foretravel Nimbus
Cummins ISM 500HP
Allison MH4000w/Retarder
Doug and Cassi Glass
Clifton Forge, VA
Posted: 06/16/08 06:00am Link  |  Quote  |  Print  |  Notify Moderator
Diesel fuel will cut the tar. That's the main ingredient in some commercial tar removers.
rebel462
ontario canada
Posted: 06/16/08 06:13am Link  |  Quote  |  Print  |  Notify Moderator
Diesel fuel, then wash with soap and water,then good coat of wax.
Twomed
On the road USA
Posted: 06/16/08 07:51am Link  |  Quote  |  Print  |  Notify Moderator
Now I know that the small stone that got jammed in the idler pully and shredded a serpentine belt on mine was not a one and only. Good reason to check engine compartment often.
Happy Trails
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
Beagle RC Air
Washington
Posted: 06/16/08 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Give GM Engine Shampoo a try. I bought this product by the 5 gal cans for cleaning engine compartments and it works. Water soluble, you probably won't have to scrub to get chip sealer off. You can buy at most GM dealerships. Diesel will work fine also.
2002 Alpine Coach MDDS
