RV.Net Open Roads Forum: Fifth-Wheels: How often do you check lug nut tightness?
 > How often do you check lug nut tightness?
swebber
Brunswick , MD
Posted: 06/16/08 05:45am Link  |  Quote  |  Print  |  Notify Moderator
Lug nuts and tire pressure checked before each trip out off the driveway. On Long trips I check again before the ride home (about 200 miles).
As for the guy checking his lugs every 100 miles, if it makes him feel safe going down the road who are we to argue.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
biljo99
Bonaire, Ga, USA
Posted: 06/16/08 05:59am Link  |  Quote  |  Print  |  Notify Moderator
Every trip I check air pressure and torque lugs.
2008 Ford F450 CC PSD LB DRW 4.30 Moonroof King Ranch 6.4 auto Tow Boss Navigation Sirius/XM radio Audiophile
Reese 16K hitch
2004 Everest 364Q MotoSat MD500
Sinterior
BC Canada
Posted: 06/16/08 06:09am Link  |  Quote  |  Print  |  Notify Moderator
BlackSilver wrote:
I have aluminum wheels (I know, kinda dumb on a trailer, but that's what came on it!) and check about every 3-4 days on a long trip. Keep a torque wrench set at 140#, and very occassionally notice they're not quite up to spec, but have never found one "loose" either.
I think every 100 miles is prolly overkill but don't ignore them either.
Hi, it sounds like you have a "dial" type of torque wrench that clicks at the setting you dial to? To keep it accurate I suggest you dial it back to "zero" after torquing as they can become inaccurate if kept dialed up.
Peter
tvman44
Southwest Louisiana
Posted: 06/16/08 06:22am Link  |  Quote  |  Print  |  Notify Moderator
After removing a wheel I torque at abut 50 to 100 miles then after that abut 250 miles then maybe every other time I use the trailer. Never find any loose after the first 250 miles, very seldom find any needing torque after the first 100 miles.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Endricken
Alabama
Posted: 06/16/08 06:55am Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately, the last RV Dealer who put on my tires said no need to check torque - Yeah, they put them on so tight I can't begin to loosen as I found out when one developed a slow leak...
Trailer is parked, I will try to check torque before next trip.
Once I saw a Fiver going down the road with one wobbly wheel/tire, I was able to pull up alongside and let them know.
Have a great week!
Retired USAF
Silver 05 Dodge RAM LB CTD Duallie 4Speed Auto SWD 3.73, Westin Sportsman Grill & Taillight Guards, Bully steps, Husky Mudguards, Retractable Ball Hitch, Star Performance Gooseneck Adapter, 05 Keystone Montana Big Sky 3670
outdoorsman2007
In the Woods - Somewhere!
Posted: 06/16/08 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Before leaving on a trip and every day during the trip.
lzasitko
Regina, SK Canada
Posted: 06/16/08 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Before a trip I check them all, if any are loose I will check when I stop again otherwise I leave it until I leave to come home. I carry a 3/4 breaker bar and a section of 1x1 tube to give me more leverage when removing them. That said I have not had any need to take them off on a trip, no punctures etc. I do carry my new jack, a 12 ton hydraulic/pneumatic so you can jack it up by hand or if you have access to air it works much easier. I bought it as I had a rear caliper seal leak and the disc on one side was scored too deep to have it machined out. I changed the disc and caliper on that side, other side was fine, and changed pads on all wheels. While I had it apart I also changed the rear axle seals. I always have a torque wrench along for tightening.
Pat & Karen
Maryland
Posted: 06/16/08 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
I check before every trip. I marked the lug nuts to see if there is any movement. Makes checking the wheels that much easier. Also the tire pressure on the trailer and the TV is checked before every trip. Always have the torque wrench and a air gauge in the truck.
2005 Dodge 2500 5.9 CTD auto
2007 Jayco Jay Flight 31BHDS
1963 DH IAFF 1664
1963 DW TABCO
1995 DD
2005 Ddog
I wish I was smart enough to put a picture hear. I guess you will have to use your imagination.
Chuck&Gail
In the Colorado Mountains
Posted: 06/16/08 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
In spring, and before each trip over 5000 miles. Rarely find any loose, and then only a tiny bit, but we have steel wheels.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
Fire5er
Port Orchard, WA
Posted: 06/16/08 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
Before every trip I check air pressure and torque lugs.
