RV.Net Open Roads Forum: Fifth-Wheels: How often do you check lug nut tightness?
 > How often do you check lug nut tightness?
woodburner
Mentor Ohio
Posted: 06/16/08 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
KCTJ wrote:
Before every trip I check air pressure and torque lugs.
ditto. Mfg. recommended it and I do it.
http://www.everest-owners.com/
RonandConni
Greentown In
Posted: 06/16/08 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
We check both the lug nuts and the lug nut torque before each trip. I usually then check the tire pressure every few days and the lug nuts every week of the trip. Have never had a loose lug or tire pressure problem but it is better to be safe than wishing I had taken just a few minutes to check.
Good luck and happy camping
WE GO WHERE WE ARE TOWED!
Ron and Conni
Greentown, In
Cedar Creek 29LRLBS
Ford F-250 6.0 Diesel
HUTCH45
NORCAL
Posted: 06/16/08 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
Same here...pretty cheap insurance IMHO...(I have 16" aluminum wheels)
"HUTCH"
'07 SILVERADO 3500HD 'CLASSIC' DRW - CC - 4 X 4
'07 NEW HORIZONS 35' 5th.Wheel 'MotoMover'
'06 HONDA 106hp.VTX1800 w/'HANNIGAN' Sidecar
"PRIMO" The Boxer
jhufft
CALIFORNIA
Posted: 06/16/08 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
I would check them each time you go on a trip I had bad experiece on losing a whole tire on a single axle on the freeway you can bet I check mine every time I go on a trip
jason
The Harpers
Carmel, California, USA
Posted: 06/17/08 12:11am Link  |  Quote  |  Print  |  Notify Moderator
Anytime we have work done on tires and wheels. I check after a real bad road. I have seen a 5er setting on the side of the road with one wheel gone. When I stopped to ask if I could help he told me his lug nuts sheared off.
Tom and Sydney Harper - Monterey California 2004 HitchHiker II LS 32.5 UKTG 2003 Chevy Durmax Diesel Travel companion our faithful rottweiler, Addie[b][/b][b]
Note: Due to invalid formatting, all formatting has been ignored.
gcooker
Fenton, Mi
Posted: 06/17/08 05:53am Link  |  Quote  |  Print  |  Notify Moderator
Steel wheels. I check my lugs every spring but in general every trip or every other trip if they are short. I check the tire pressure every trip. I check closer if the wheels have been pulled for some reason. I just use a wheel wrench - nothing fancy. The thing to wonder is I almost never check them on my truck
2001 F350 SB CC 4x4 smoker & 2005 Wildcat 31qbh
rowaltonjr
Castle Hayne, NC
Posted: 06/17/08 11:21am Link  |  Quote  |  Print  |  Notify Moderator
We check pressure & wheel nuts before every trip & then every couple of days of driving. I was checking lug tightness in a camp ground in Cresent City, CA last spring when our next door neighbor saw me & said he had never seen anyone do that so we checked his, several were loose. Better to take the time than to have a problem because you didn't.
nogo
2004 2500 Sierra, 2006 Keystone-Cougar 291EFS 5th wheel
We don't do anything, but we do it real well
RV camped in 49 states, every province & territory of Canada & 2/3 0f Mexico
dieseldan723
Pacific NW
Posted: 06/17/08 11:36am Link  |  Quote  |  Print  |  Notify Moderator
BCinWI wrote:
1-2 times per year.
Same here. Never found one loose yet!
2006 Forest River Cardinal 33TBH towed by 2003 GMC 2500HD - maybe some mods!
Pullrite Superslide, Prodigy.
RanchDweller
Colorado
Posted: 06/17/08 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
What is the deal with the aluminum wheels vs. the steel wheels. Is there more play with the aluminum ones? Is the metal more susceptible to expansion and contraction?
gar_fanatic
Iowa
Posted: 06/17/08 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
I check the tire pressure before each trip, but have yet to check the torque. We're going to be re-packing the wheel bearings anyway soon, so they'll get torque'd then.
'93 30' wilderness
'97 Ford F-350 crew cab diesel "the haulin hawg"
