mitchkim
north carolina
just took the tt out for the first time this weekend
i had no hot water pressure in my lines
all i could get was a trickle of hot water
heater is working fine
if i turned the valve on the bypass line to bypass the hot water heater i got good pressure
so i took the line off at the tank where the hot water comes out
noting is coming out of the tank there
then i took a little like check valve out of the line and put in back together and it works like it should
put the valve back in and no pressure
what is this valve and what is its purpose
why did it all of a sudden keep the pressure from going through the line
can i run my heater with it removed
2002 hornet w/slide 34 ft 2 bedroom sleeps 10
reese dual cam, prodigy brake control
2003 dodge ram,ho cummins diesel,auto,quad cab light almond,2wd,trailer tow,posi-trac
me the wife the 15 year old daughter(who has a mind of her own) and mom
LAdams
Northern Illinois
The check valve is part of your bypass system... A lot of manufacturers use a single valve system with check valve rather than using a 3 valve system... These check valves are prone to failure...
No you won't hurt your system by removing it but you'll either have to replace it or revamp your bypass system before winterizing again...
Les
last
edited 06/15/08 09:33pm by LAdams *
View edit history
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
** NEW ** blog.rv.net
Catfishman
North Texas
>>then i took a little like check valve out of the line and put in back together and it works like it should<<
Your bypass system obviously requires that two valves be positioned correctly. One will be OFF and the other will be ON. Choose the position that will allow flow of water INTO the tank to be heated.
2003 GMC Sierra 1500
5.3L - 3.73 Ratio
2002 Coachmen 249QB
If you can't fix it with a hammer, you've got an electrical problem!
nny12972
NY
That "little check valve" on your CW line is there to save your water system......if you fire up the HW without it, the expanding HW can over-pressure the water lines and blow them....particularly with recent installation of crimp-fit water lines.
J
LAdams
Northern Illinois
The check valve should be in the hot water line... The check valve is there to prevent backflow into the water heater when the system is set to bypass... Don't think anything is going to blow up if it's not there and the valve(s) are positioned properly...
Les
heavyputer
Ontario, Canada
Sounds to me like you have the check valve installed backwards. Flowing in the wrong direction. JMHO
Heavyputer, 1 DW,
1999 F250 SD SC 4X4 V10 3.73 Husky 16K 4way tilt hitch
Prowler 295R 5er front living room model
clintbonnie
Kent, Wa. USA
Had the same thing happen to my American Standard tank a couple of weeks ago, just a very slow dribbling. I also removed and check the check valve which seemed OK..
With the valve removed, i then looked down the pipe into the tank and found white plastic blocking the pipe, just inside the tank.. Pushed lightly on the plastic and it broken away.. I then put everything back to together and it works great..It is kinda weird but I am keeping a eye on the situation. But after our 4 day outing this past weekend, it seems to be working normally..
nny12972
NY
I beg to differ, MOD.....According to SHURFLO C/S, AND as is very clearly illustrated in their installation instructions, "the little check valve" is installed protecting the pump and cold water side of the FW system (NOT the HW side)....AND, without that check valve, if the HW tank is full before it's fired up, it can certainly blow o-rings in pumps and sloppy PEC connections (particularly in cooler weather, when PEC contracts and connections aren't as tight)......seen it many times....
J
clintbonnie
Kent, Wa. USA
nny12972.. there is also a check valve in the "hot water" side on the outlet of the hot side of the hotwater tank on some RV's. My Arctic Fox is this way.. I believe it there just to eliminate a manual valve during winter storage when adding rv anti-freeze..
LAdams
Northern Illinois
Like I said - it depends on the layout of the Bypass and if it's a single valve or double valve...
Take a look at the 1st and 4th picture in step 3 of this link and you'll see the bypass in the HOT WATER SIDE of the heater... I have never had one in the cold water side but then I usually change mine over to a 3 valve system which I prefer as the check valves are prone to failure...
http://www.parkmodelhomes.ca/Downloads/rv_winterization.pdf
Les
