RV.Net Open Roads Forum: Fifth-Wheels: Bubbles in walls
 > Bubbles in walls
AnnM
Fort Bragg, CA 95437 USA
Posted: 06/16/08 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
I have noticed the wall in our fiver has bibbles in it. To feel them they feel almost like sand there was sand in the adhesive. Today I noticed it seems to be getting worse. I have no idea what the problem is. There are no leaks. My only other thought is condensation although we do use a dehumidefire during the wet season. Any ideas?
wayne_tw
South Dakota/Georgia
Posted: 06/16/08 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
Delamination caused either by water entering the wall cavity or poor adhesion during the construction. Since you have to use a dehumidifier, I suspect you have a leak in that area.
pulsar
Lewisville, NC
Posted: 06/16/08 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
Beaker
Brevard, NC
Posted: 06/16/08 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
I had a new '99 Trail-Lite that was totaled by the insurance company in 2002 due to water damage. I never saw water anywheres in the trailer but I did see what I called "pimples" hanging from the ceiling and some "sandy" places on the wall. Dealer said no worry just some outgassing. I would look it over carefully and have a trusted dealer also take a good look.
I hope I'm wrong but sounds like water to me.
2000 Silverado 5.3
1998 23' Jayco lite
waitin'togo
Clovis, CA., USA
Posted: 06/16/08 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
We found a similar problem with the outside of our RV. We'd be talking with the service manager about problems on prior models he said was solved. When I inspected our trailer, I found the same problems on ours. I had them fix one fairly severe area and note others before the trailer got out warranty. If its severe, you need to get it to the dealer so they can at least document it, even if you don't want it fixed.
waitin'togo
2006 Jayco 29RLTS 5'r
2005 Chev 2500 6.6L Short Bed
18K Reese Slider
pritch272
Martinez, GA
Posted: 06/17/08 05:15am Link  |  Quote  |  Print  |  Notify Moderator
We had what we thought was delamination on the outside of our unit, even took pictures and posted, emailed to Keystone- they said it wasn't a problem, we thought it was, but evidently it wasn't, as the visible signs that there was something wrong has gone away.
Retired US Army
2000 Ford F250 SD 7.3 PSD, Firestone Ride-Riteā„¢ air springs
2007 Keystone Laredo 29RL, Doran Pressure Pro and Metal Tire Valves, 16" Michelin XPS Ribs, Dirt Devil CV950 Central Vacuum, 2000W AllPower (Honda Clone), 4000/3500W Champion C46540
floridacamper
Florida/Georgia Line
Posted: 06/18/08 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Condensation is the number one cause for the deterioration of a RV. Most manufacturers recommend the use of a dehumidifier year long. If nothing else at least keep a window or two cracked.
CLICK HERE FOR PHOTO ALBUM
 > Bubbles in walls
