RV.Net Open Roads Forum: Fifth-Wheels: 2nd A/C
 > 2nd A/C
mjm1
NC
Posted: 06/17/08 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know how high the 5er will be with the front ac added? I want to add one to my 35L4QB silver back but I don't want to go over 13'6". Right now the published hieght is 12'11".
Thanks for the help.
Mike
F450
35L4QB
Randyl81
Illinois
Posted: 06/17/08 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
My Polar Cub 9000btu is low profile, I will measure it and let you know.
mjm1
NC
Posted: 06/18/08 07:01am Link  |  Quote  |  Print  |  Notify Moderator
Thanks. It will help me figure out what to use.
LIJohnnyH
Long Island
Posted: 06/19/08 05:47am Link  |  Quote  |  Print  |  Notify Moderator
Mike
F450
35L4QB
Mike
I have almost the same fiver as yours, the 36L5S. I agree that that a second AC is required on these anytime it hits 90 or more outside. Did you get it prewired for the second AC. If you do this let me know how difficult it is.
John
SweetLou
La Quinta, CA USA
Posted: 06/19/08 06:00am Link  |  Quote  |  Print  |  Notify Moderator
My unhit had it installed by the previous owner. I used it last weekend. Freezes the bedroom out even on the lowest possible setting. Mine is a 13.5 btu, however it is noisy as well. I guess I will get use to it. The other thing that happens is that because the main unit is on or cycling on & off, if you are warm in the living area you can crank the bedroom up to high to send air down into the living area. What happens is that the cold air will fool the thermostat into a false reading. you have to play with the settings in that case.
2005 3500 Cummins HO Quadcab 4x2 3.73 6 spd man, 2007 HitchHiker Discover America 329 RSB
 > 2nd A/C
