kosko1
alaska
Anyone know if there is a way to install the removable Pingel chocks through the floor using something besides the nuts and bolts they come with. Thx
SoCalDesertRider
SanDiego, CA, USA
A hitch pin maybe??
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
SMarquez
Rancho Cucamonga, Ca
I found a cross member behind the tanks to anchor mine. I pre-drilled and used self tapping torx head screws. I went under to make sure there was nothing to hit when I drilled. I mounted one to roll the bike in straight in and another at the back of the trailer to load cross ways. 1200 miles, so far no problems.
lwlam
Corona, CA
I have a similar issue. I have a WW Superlite 5er. The underside is covered with a black insulation type material (kinda like black plastic wrap). I cannot actually see the underside of the plywood floor. Can I secure the mounting hardware using thick wood screws instead of lag bolts w/ nuts?
Thanks
Lester
Lisa
Lindsay
Loren
Langdon
Leland
2008 Ford F-350 Crew Cab 4x4 LB SRW
2008 Weekend Warrior SL3005
2005 Ducati S4R (Street)
2001 Honda CBR600F4i (Racetrack)
rdam
Lake City, Florida
If you have the ability, use something other than a "Pingle" chock. They are near useless for any full size motorcycle. Try something like a "Bike-Pro".
2006 Weekend Warrior LE 3505
2004 Ford F-250 Supercab 6.0L Diesel/Auto
rdam
Lake City, Florida
lwlam wrote: I have a similar issue. I have a WW Superlite 5er. The underside is covered with a black insulation type material (kinda like black plastic wrap). I cannot actually see the underside of the plywood floor. Can I secure the mounting hardware using thick wood screws instead of lag bolts w/ nuts?
Thanks
I just installed "Bike-Pro" chocks from my old trailer into my WW LE3505. The "black plastic wrap" is thin, and you will drill right through it. Ignore the wrap and install with a backing plate or LARGE washers.
PegLeg2000
Michigan
rdam wrote: If you have the ability, use something other than a "Pingle" chock. They are near useless for any full size motorcycle. Try something like a "Bike-Pro".
Couldn't agree more!
I have Pingle chocks in my 7X12 Haulmark motorcycle trailer. Put Condor's in my KZ. WOW, what a difference! I've hauled my 2 Electra Glides in the haulmark all over the US and Canada and have to fuss with the bikes on almost every stop due to the sloppiness holding the front wheels in the pingles.
Traveled from Detroit to Daytona and back in the new KZ with the Condors this past March... Didn't have to touch the bikes once!
I'm a believer! The pingles in the Haulmark have to go!
My 2 cents...
Rich
2008 KZ New Vision Sportster 40P
2008 F-450 King Ranch 4X4
rdam
Lake City, Florida
PegLeg2000 wrote: rdam wrote: If you have the ability, use something other than a "Pingle" chock. They are near useless for any full size motorcycle. Try something like a "Bike-Pro".
My 2 cents...
Rich
Same here. I have travelled with friends who were using the Pingle. At one stop we checked the bike and it was leaning against the inner wall and scuffing the fairing. I have used the Bike Pro for THOUSANDS of miles, and never had one issue. I know the Condor is similar. I just can't see putting an $18,000 motorcycle in a $40 chock.
yardsale1
Orange County, California
What about Etrack chocks? That is the way to go IMO. Look for Mackie Enterprises. He is on Ebay. I have six of them, could not be happier.
2007 Keystone Raptor 299MP
msully
So Cal
I mounted mine to a 12" x 24" piece of 3/4 plywood. With four tie downs, two on the handle bars and two on the rear sub frame of my mx bikes, it is all I need to keep them stable. Sometimes I go out with 5 bikes, some times I go out with 3 bikes and two quads, other times I only have 3 bikes. I can move the chocks around where ever I like with this set up. They are totally stable and have never had any issues in over two years of using this set up. I would only recommend this for dirt bikes however.
