RV.Net Open Roads Forum: Hybrid Travel Trailers: Electric Brakes
Open Roads Forum  >  Hybrid Travel Trailers
 > Electric Brakes
woodhaven
Brandon
Posted: 06/16/08 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
Our electric brake controller has stopped working. Does anyone have any details on what the pins are.
Thanks
kaydeejay
SE Michigan, USA
Posted: 06/16/08 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
It would help if we knew what the make of controller was.
Also, what are the wire colors?
Keith J, Retired from GM Engineering
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA.
1999 Sunnybrook 27RKFS Fiver
Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors.
redrunner&roo19
winnipeg manitoba
Posted: 06/16/08 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
Is it the controller or the wiring in the plug at the hitch, this usually goes first.
Chuck_S
Broadview Hts, OH, USA
Posted: 06/17/08 07:57am Link  |  Quote  |  Print  |  Notify Moderator
The controllers all have leds to show there's power to them. No power. No brakes. Common for folks with antique technology time delay controllers to turn them down in city driving. Down too far and no brakes. Total brake controller failure is rare.
Connectors are the weak point in all electronic and electrical devices. Start with the controller and work both ways. Bubba or UHaul wiring can be problematical. Factory interfaces and wiring rarely has problems -- another reason for the factory HD Tow package.
You can do any of these tests in any order.
If the controller has power and indicates braking when you press the pedal test connector on the back with the blue wire with a volt meter or 12v test light. Should light at brightness dependent on the control setting as you press the brake pedal.
If brake power is getting out of the controller check the Bargman connector on the back bumper. You'll need someone to hit the brake pedal.
At that point it's time to get under the trailer and look for broken blue wire to the brakes and good grounds. Since broken wires are often obvious you may want to check here after confirming the brake controller has power and changes cycles as you press the brake pedal.
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
fdwt994
Indianapolis, IN
Posted: 06/17/08 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
This recently happened to us. The connector (socket) at the bumper was corroded. Cheap part and fairly easy to replace if you're comfortable with some basic wiring.
woodhaven
Brandon
Posted: 06/19/08 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Good-day,
The problem was the socket corroded at the bumper. I'll be changing that part out this weekend.
Thanks
TheGrinch
Western MD
Posted: 06/20/08 07:49am Link  |  Quote  |  Print  |  Notify Moderator
I take a little emory cloth to my contacts occasionally and make sure the wiring is solid every Spring. Some PM is always worth it.
TheGrinch
djdetrick
PA
Posted: 06/21/08 09:26am Link  |  Quote  |  Print  |  Notify Moderator
I put Dielectric grease on all contacts stops corrosion never any problems.
Dave
DW DS DD
2006 Rockwood Roo 233
2007 Ford F150 Supercrew 5.4L Triton
 > Electric Brakes
