alaskan-rver
Anchorage, AK
This past weekend my Scangauge II quit working on my E-450 motorhome, but continues to work fine in other vehicles (I tested it on two Dodges). On the motorhome, it acts like it isn't even connected (nothing comes on, etc.). Any idea what the problem might be?
ib516
Up here!
Is there a fuse for the OBDII port? I know the scangauge gets it's power from the vehicle...
2004 Cougar 301 BHS 6580# Dry, 9000# wet, 9600# GVWR)
2007 Dodge/5.9L Cummins 3500 SRW Megacab 4x4/3.73
Hypertech Max Energy
"MEGACASPER" 10100# GVWR, 5200# FGAWR, 6200# RGAWR
PICTURES
ELIM 3000 Gen (still going )
Collision Reconstructionist
ScanGauge2
alaskan-rver
Anchorage, AK
ib516 wrote: Is there a fuse for the OBDII port? I know the scangauge gets it's power from the vehicle...
I was wondering the same thing, or at least how to probe the OBDII port for signs of life...
Wherever I happen to park
You need three things to probe the OBD II connector
One is a pin out, Any auto service manual for your engine line should have that
The others are a logic probe for the data line and a test lamp or voltmeter for the power line
And that's it
carringb
Corvallis, OR
OBD port shares fuse with cigarette lighter in the E-series
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, 230,000+ miles
Had: Weekend Warrior 41' FSW (still looking for its replacement)
ozhoo
Anza Borrego Desert
carringb wrote: OBD port shares fuse with cigarette lighter in the E-series
People have been know to plug power hungry devices into their lighter sockets and pop the fuse. This is one of the little known side effects (at least on the Pords).
O
2003 F350 6L 4X4 Auto Dually
2003 KZ36P2 Off-Grid Toy Hauler w/ 650 watts of solar feeding (2) networked Blue Sky 3024i CC, charging 660aH Lifeline AGM bank.
Know before you tow... Towing Laws by State
alaskan-rver
Anchorage, AK
...we have a winner! That solved the problem--I spent far longer tracking down my owners manual to figure out which fuse it was than I did in the actual repair.
Bryan, I owe you a cold beer when you come up this far north.
oldusedbear
Brookings, OR, USA
Where DOES that pesky fuse reside?
On edit after finding it: On my 2001 E 450 it is up above my imaginary clutch pedal. REALLY convenient. Open the driver's door, sit on the step, get a flashlite, turn your stupid bifocals upside down, pull the cover off the fuse panel, try to read the stupid numbers, and to top it all, these are the VERY small type of spade fuse. If yer a klutzy fingered type, one of those little bitty plastic fuse pullers is a big help in getting them out.
Replacing the fuse tho, DID light up my ScanGauge and the cigarette lighter socket.
edited 07/06/08 02:17pm by oldusedbear *
The reason for spelling is so that all of the words don't look the same.
cdzranch
Snowflake Az
I have the exact problem on my workhorse w-22 w/ 8.1L vortec. Any special fuses I should be looking for? Sorry for sharing your thread.
Dan and Cindy FMCA# 402249
2002 Itaska Suncruiser 37ft (1) slide W22 Workhorse chassis; 1990 Komfort Trendsetter 25ft 454 4bbl carb
Tow VW manx bug; '07 Honda Shadow 750
Snowflake Az.
"If you don't learn something new every day, you've wasted that day!"
