RV.Net Open Roads Forum: Is there a trick to removing plastic hub covers
 > Is there a trick to removing plastic hub covers
kdkrause
Redcliff AB Canada
Posted: 06/17/08 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
Our 2009 Trail-lite came with plastic "chrome look" trim rings and hub covers. In order to check the lugnuts I have to remove the hub covers. Is there any easy easy way to remove these? The covers are just plastic and I am worried about breaking them.
DarylD
Fridley, Minnesota
Posted: 06/17/08 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
My Jayco Jayflight and my TV (Ford F150) have those type of covers. They are simply "snapped" on, or "pressure fit" over the lug nuts.
My TV has a small slot on the cover, but against the rim that allows me to put a screw driver or something to pry them off.
Good Luck and be careful. They are plastic.
HAPPY CAMPING!!!!
Daryl and Sandy D.
2007 Jayco Jayflight 25RKS
Ford F150
Equal-i-zer Hitch - Prodigy Brake Controller
Pat & Karen
Maryland
Posted: 06/17/08 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
I took a metal coat hanger and bent it into a hook. Place the hook part into the slot and gently pull. It should come off easily. This was easier for me then using a screwdriver. I am sure someone makes an expensive specialized tool just for removing hubcovers.
2005 Dodge 2500 5.9 CTD auto
2007 Jayco Jay Flight 31BHDS
1963 DH IAFF 1664
1963 DW TABCO
1995 DD
2005 Ddog
I wish I was smart enough to put a picture hear. I guess you will have to use your imagination.
skipm
Saint Helena Island, SC USA
Posted: 06/17/08 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
Mine have a single screw on one of the edges that has to be removed then it tilts from the screw side to disengage some fingers from the opposite side of the cover.
Deedle
Hesperia, CA
Posted: 06/17/08 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know where I can get center hub covers, When I took my trailer in for breaks and a seal job, I think they put them on wrong because 3 of them came off. Thanks for any help.
mockybird
Mocksville,NC
Posted: 06/17/08 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know where it came from, but in my toolbox I have a "thingy" that is like a flat-head screwdriver on 2 ends, but has 2--45 degree or so bends in it.
This works much better than just a screwdriver I find. That angle gives you something to pry against.
Gary
Coyote2cool
Denver, Colorado
Posted: 06/17/08 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
My awning bar that grabs the strap has a hook at the end. I use my awning bar to pop the center caps off.
Tim
2008 Chevrolet Avalanche Z71
2007 KZ Coyote 23 CFK
2008 Total nights camping = 27
Just Remember: When everything is coming your way, you're in the wrong lane
Me (37)... DW .... DD (11) ... DD (9)...Dog (1)
Camping photos & Mod's
Hgarnerno1
Tyler, Texas USA
Posted: 06/17/08 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
I lost three of mine on the first trip when new. Now 6 years later I still have one left.
Howard, USN Ret
2000 Ford Excursion,V10, Limited
2003 Terry 27H. Super Slide
Ductape
On the Road
Posted: 06/17/08 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
Ours has the white covers that snap onto the lug nuts. I just grab them firmly with one hand in the center and yank 'em off.
Surveyor SV-234 >Equalizer> H3
Previously a fiver crew.
swebber
Brunswick , MD
Posted: 06/17/08 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
I use this tool from Snap-On, a cotter pin remover, to get my covers off.
Check out any auto parts store for a similar tool.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
