RV.Net Open Roads Forum: Travel Trailers: leveling question
 > leveling question
dawg37179
Thomsons Station, TN
Posted: 06/17/08 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
I have a question. I've been looking at the yellow leveling blocks @ CW that look kinda like leggos. How do you use these with a tandem axle TT? Does one tire just hang in the air? Do I put one under each tire? If so, how do I get the one for the rear tire between the tires? HEEELLLPPPP!!!
Thanks all!
* This post was edited 06/17/08 08:16pm by an administrator/moderator *
mikehart92
Oklahoma
Posted: 06/17/08 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
Under both axles.
Mike
Boilermakers Local 592
2005 Chevy 2500HD.............6.6 D/A, 4x4, Crew Cab
Rumtan
Alberta
Posted: 06/17/08 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
If your just levelling one side, I just use a 4ft 2x6 and park on it.
2002 Palomino 22'
2002 Chev Silverado V8
Fish-O-holic
campingfunfinder
Indiana
Posted: 06/17/08 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
I use 12" by 12" boards. I place one or two in front of each tire on the side I want to raise. Your leveling blocks should fit between the tires.
2002 4Runner
2006 Fun Finder 189FBR
HighCover
Fort Worth
Posted: 06/17/08 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
Put a stack in front of each tire on the low side of the trailer and pull it up onto the blocks. The chock the other side before you unhitch ;~)
2007 Tahoe, 5.3L
Rockwood 2306
TallTeam
Illinois
Posted: 06/17/08 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
We tried the yellow stacking "lego" looking blocks and pitched them. They only work on level ground. The break on uneven gravel or dirt. They were not worth the money.
LAdams
Northern Illinois
Posted: 06/17/08 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
First of all - there is no such thingas a dumb question... If you don't know - - ask!!! That's how WE ALL learn and that's what these forums are for...
Yes, put one in front or behind each tire and pull up on them or back up on them... To make them higher, put two next to each other and then lay another one over the top of both of them interlocking the two together...
And if the ground is not level you can take the edge of one and scrape off enough dirt, rock, whatever to level them... Some of us carry a small army shovel for this purpose...
I carry two sets of them and also some small pieces of 3/4 inch plywood that can be used for fine adjustments or stacked for a bit more height...
Keep asking questions - we'll answer them to the best of our ability - - and a big RV.Net welcome to the Forums ...
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
** NEW ** blog.rv.net
swebber
Brunswick , MD
Posted: 06/17/08 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
In the three years I have had ours I have not had any problems with them on gravel, dirt or grass.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
Ductape
On the Road
Posted: 06/17/08 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
We broke a lego on soft ground last week. Got them as a gift, otherwise I'd stick with the boards. cheaper and better.
And you need to lift both tires. Don't put all the weight on one tire.
Another technique you can use is get in your position, make a mark in the dirt where each tire centers, then just back up a few feet. Place your blocks at the intersection of the tread marks and your mark, then pull forward to that same spot again.
Surveyor SV-234 >Equalizer> H3
Previously a fiver crew.
Fire Instructor
Upstate (Albany) NY Area
Posted: 06/17/08 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure of the colors/brands, but the yellow ones seem to bust-up very easy, while the orange ones seem much more durable.
Fire Instructor
2004 Dodge 1500 4dr 4x4
2009 Rockwood 2607
"If everyone is thinking alike, then somebody isn't thinking!" General George S. Patton
 > leveling question
